Sponsored by: CARiD
W212 Radiator fan turns on when ignition off
Old Oct 6, 2023 | 05:14 AM
Wisswass's Avatar
2010 Mercedes E250
Hi.
When i turn off the ignition and remove the key, the cooling fan, starts to run at high speed.
And fan stops when i turn on ignition.
I noticed that the fan doesn't run when ignition is off, and the diagnosic (a cheap one) is attached to the OBD.
I've checked fuses in fusebox in engine compartment.
Can the battery cause a problem like that?
While driving, I've a voltage over 14.5v and 12.1v when the car is shutted down.
Where do I start to fix this problem?
Old Oct 9, 2023 | 08:00 AM
S-Prihadi's Avatar
Originally Posted by Wisswass
Hi.
Read the attachment
The answer may be there...........
File Type: pdf
Old Oct 9, 2023 | 10:55 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Interesting case of busy fan...
Where you start to fix this is... by reading the WIS document carefully researched by @S-Prihadi then you understand the smart FAN has a mind of its own in this Bosch system.
There may be nothing wrong with your fan system because it is able to turn off ie. it positively receives ECU PWM control else it would keep blowing regardless of control.
Can you confirm your fan never spins on cold engine, right?
The voltages you report are coherent with normal function.
Go ahead, scan your car for codes then translate faults in plain English descriptions. This will provide us an idea of what's at play.
In addition go ahead and specifically read :
  1. Engine coolant temp sensor
  2. AAC pressure sensor
  3. (Coolant tank level !)
You will have empowered yourself by completing these checks.
