W212 brake replacement - calliper specific help needed
I've watched a load of videos on how to replace front pads and discs but all the front brake callipers look totally different to my car
The car is a 2013 S212 E350 bluetec ( face lift ).
Could someone please send me a link to a good youtube video on how to replace the brakes with this style of calliper?
Thanks!
However, you need brake grease for those pins.
Your caliper is the same as mine and the above video, 344mm Brembo 4 pistons, 2 + 2 pistons actually
When u are decent with it, make it zero touch : https://mbworld.org/forums/e-class-w...y-achieve.html
Front Brembo 4 pistons for zero touch is possible, the rear being a single piston is a hit a miss.
The internal of the brake caliper if you want to see them. is here : https://mbworld.org/forums/e-class-w...-overhaul.html
