What is this engine knocking noise?
I found a bunch of other threads someplace about faulty piston boring or rings or something on certain vins for w221s, but my vin falls outside of that range.
Thanks for any help
Whats the ages on the idler pulleys?
Engine & trans mounts?
I also have a noise Im tyring to track down but it's not the same as yours. I've done the pulleys and the tensioner, Some how car still has original 2010 engine mouts
I have the M273.
mounts and pulleys are original but it also only has 97k miles. I bought it at 48k and it's been making this noise since I got it some odd 5 years ago.
There's no engine mount play or vibration, no observable problems and no xentry codes. :/
GL hunting down your sound though!
Regarding the balance shaft issue. It was an issue prior to 2008 and was corrected.
I enjoyed looking up the balance shaft issue, I wasn't aware of it. I skipped the w211, going from w210 to w212 so I've very glad I lucked out on that. Not so glad I have failed piston rings in my gl320 though...
Anyway, thanks for all the help. At least I know its not a bunch of things, but I'm still clueless as to what it might be.
Mine has the knock. It is quiet when the engine is cold, but there when the engine is hot. Only present at idle. It has been that way for 10's of thousands of miles. Had a lengthy discussions with another forum member with a M273 his was similar in the it has been there for awhile. Though to be honest I am starting to work on the front end and would hate to invest the time and money to have this deteriorate to the point of becoming an issue. I am at 150K hoping to make 200K. I will tell you it did make me nervous a year ago when I was up in Canada ie far from home and would hear it.
Was your recording at idle? The other thing that is weird from you account, is that you can't hear it outside the car. I don't hear it inside the car but definitely outside the car. For me it seems to be coming from the front passenger side.
The correct way to determine if it is scoring is to get a boroscope and look at the cylinder walls. I have not done this because what I am I going to do with that finding? ( I am assuming that it is present).
If you're idling does your knocking stay at exactly the same interval (which would be logical given the pistons scraping the walls at the same rpm). Mine specifically will speed up, as it did in my recording at the start, then simply disappear some seconds or a minute or two, then come back sometimes at full speed and sometimes slowly building back up. All of this at idle and in park.
Plastic idlers are actually better than metal ones to isolate from belt heat. It sounds cheaper but actually it delivers less premature failure.
Everything must go as a kit (tensioner + belt + idler pulleys) for a chance to save the life of your accessories (compressor, alternator, pump). These are keepers if the tensioner plays fair
. What is the good German OEM brand of tensioner...???
We know belt is Continental, best rubber mfg in the world.
Stupid lyme brain, literally the first thing I thought to check I just couldn't remember. Anyway case solved.
How does this part look like... picture?
