Sponsored by: CARiD
Blower motor keeps running
Old Nov 29, 2023 | 12:18 PM
donny79's Avatar
e350
I put front defroster on this morning, after car was hot I pushed off button, the fan kept running, I get to work turn car off blower motor kept running, I had to go under glove box to disconnect the blower motor fan. Anyone know why this would happen out of the blue?
Old Nov 29, 2023 | 03:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
heads or tails...
> SMART HVAC :
There's a fair chance this is normal.
-- The AAC HVAC module tracks temperature and moisture levels.
It tries to dry moisture from the AC evaporator coil and prevent windshield condensation.
-- The timings for this game are enforced by the F-SAM that should cuts off power when sleeptime is up regardless of rain or thunder, power times out!
-- I like your idea of disconnecting stupid blower to preserve crank battery.
> EASY:
--1-- Without doing extensive investigations... you can try to prevent this condition by switching AC:OFF and using HEAT-only instead .... at least for sanity testing.
--2-- Do yourself a favor, Reboot the car for a chance to refresh soft-cradhed CAN-B members.
An automated watchdog function is missing. It's an understatement to say these systems are not built to be reliable.
Let's not chase our tail with this mad game.... reboot!
> BATTLE TIME:
--1-- When you have time, get scanning for faults and live HVAC data. You will gain insight on what sensor HVAC data is acting upon.
--2-- There are multiple factors that can combine to help HVAC disfunction :
  1. Solderless moisture sensor
  2. Solderless AAC module
  3. Painted footwell GND
  4. CAN-B signaling
  5. sensor/actuator faults
As you remove disrupting factors, these systems will act well under stressful conditions such as low voltage.
Draining a poorly charged battery to prevent windshield fog is a recipe for chaos. We'll try to help W212 not spoil your holiday spirit.
