Directions for brake vacuum pump replacement
Request: directions for brake vacuum pump replacement
My 2012 E350 4Matic started smoking from under the hood on the drivers side. My mechanic diagnosed the issue as a bad vacuum pump. I'm going to repair it myself. Can someone please post the directions for this repair? Thanks.
I would do further research on YT prior to tackling this job yourself. I did a cursory search and came up with this tutorial but there are others that came up on the search. Good luck and advise how the repair went.
The following 2 users liked this post by Raj1471:
CaliBenzDriver (12-09-2023),
pierrejoliat (12-04-2023)
I started by looking on YouTube and also did a search on this forum. Didn’t find a video for this specific model or WIS directions. That’s why I posted. Thanks.
Anybody have the WIS pdf for this repair? If so, I would greatly appreciate it if you could post or PM it to me. Parts are finally arriving today. Many thanks.
Received 3,448 Likes
MY'14 W212 M276 3.5NA @60kMi
PUMP ONTO CAMSHAFT....
One thing to pay attention is to match the male/female groove when inserting the pump. You need to rotate the pump to meet the camshaft drive.
While working around the rear of bank#2, check the plastic cap for the nearby exhaust camshaft is not actively leaking oil to relief abnormal crankcase pressure.
Received 1,742 Likes
1922 Ford Model T / no OBD
Also in the past some members found local libraries having subscription to AllData for the same use.
