Can the Launch Creader Elite modify seat code/variants ?
There are all sorts of different options that comme to play with the seat: such as "rear collision" option...
Launch options for passenger seat
options detail 1 of 3
options detail 2 of 3
options detail 3 of 3
Not 100% exposed options are useful nor golden. Launch C-Reader gives us access to engineering menus options some of which should best left alone. Process carefully as with any software settings!
I think it would be positive to share interesting menus options we come across.
Such a blinkers count
(Battery reset in SAM?)
Every VIN has different set of options so every option won't be applicable to all cars.
Module collection by LAUNCH cReader 1of8
2of8
3of8
4of8
5of8
6of8
7of8
8of8
I like that cReader does not ignore the many LIN Bus devices the way my Autel MaxiDiag does.
This scanner is another special gem introduced by @S-Prihadi as far as I know.
> READING "TEA LEAVES":
When you pop your head backstage, things become more interesting.
I call this "reading tea leaves" because a lot of it misleading. It's like reading a stock market report: everything is true but it does not fully describe reality.
Many modules report errors as Current/Stored - They all mean something to the wiser.
Stored are simply not "hard errors" but can be current transients.
The wording is misleading but don't let that stop you: learn this for what it is.
Many faults have misleading vague descriptions ... Ex: camshaft correlation codes that point to everything except the culptit reluctor wheel.
Don't rush to replace good OEM parts with aftermarkets.
> The
The faults you'll hardly ever hear about have no error codes. Your scanner will show smiley face and car will still be sick!
These faults are not tested so they can remain ignored unflagged, peacefully creating controlled havoc and surprises.
- Battery drain while parked: F-SAM DCU
- Gremlins factory : STRAP
- Sick Main AGM: ECU R-SAM
- Slow-poke M276/8:
The hard part in troubleshooting correctly is to investigate facts and connect the relevant information.
Luckily our cars are built to high standards with everything necessary to run and then disfunction predictably.
I was puzzled to realize that when my new Benz had bad brakes and bad battery before 10kMi... so I took care of this myself: 10 years later same original battery and same original brakes - That's the difference between multiple service calls vs. one repair job.
At the moment, I am interested in how deep the variant coding option goes, and if it allows changes or just lists possible options.
The version of my seat controller may be slightly different than earlier/later software/hardware - This flexibility to adapt is the beauty of German engineering.
Okay, let me go dig some for ya
> Nothing's Perfect...
It's funny you flag that option because "Variant coding" seat menu option open a 2 screens deep list in which "variant coding" is also part of... confusing!
round robin nested option
Let me see what's inside that nested one... now
- Here is my complete set:
Other point of interest with cReader are NORMALIZING POSITIONS for:
- seats
- sunroof
- HVAC Actuators
- door windows
normalizing seats
TIP: TAKE A SCREENSHOT+ PICTURE.
You are going to flip a bunch of settings and come Monday you wish you had a list of those settings.
3x screens full of HVAC Settings:
customize to your likings
LAUNCH touch screen Android scanner... genius, Thank you MS!
++++ EVAP TEMP REGULAT
I couldn't resist changing this EVAP CONTROL
You can pick your own comfort options
ECU... YoYo + Solenoid
SAM + CGW
ESP
SSCM
ISM
DCU
KEY-G
Ppl fix wipers and flat tires... now it's time to recognize MB networked Modules as recipients of much needed care.
On the high speed network it's 8AM rush hour traffic jams . Each time you loose a goody module something starts working better - Good game if you know what you're after fixing: >>> POOR TIMINGS: wasted cyclesake slow delayed at every level both computation + networking.... ouch performance impact.
The VIP modules like bi-monthly reboots just like golfing...
Seriously fast scanner on tuned CAN-Buses. It's a pleasure to play around, like this car now.
Yum-yum
++++ very fast & stable scanner 👏
Go open up your ICLUSTER options galore
(was looking for Temp Gauge tweaks)
A couple of days ago, my passenger seat stopped moving forward or back. I used my Creader tool to diagnose the problem. I tried calibrating the seat because I have two current DTCs: B1D9B54 and B228678. Those codes say the seat needs to be calibrated, but calibration fails. It appears that the is a problem with the Hall sensor, which I understand is part of the fore/aft motor.
I can almost guarantee the sensor is all right but something else is helping position signal get lost.
90% chance it's just a poor connection as follows:
-- The W212 seat modules are not solderless but have poor soldering instead. Do a physical check.
-- Of course the seat uses painted GND at chassis chair-rail.
-- With everything made good, you can trace a schematic to see what circuit motor sensors work with.
Juan, I come to realize I shouldn't have messed with my A/C without asking what you think.
-- Default is: fixed at 2°C above icing
-- Advanced is: variable based on humidity.
Do you have a strategic opinion for evap target temp?
- Of course we can leave it with "2°C default" but the HVAC Controller can "save energy" by varing that target temp for dehumidifing in winter without cooling.
- Lower serpentine load, less A/C Temp Cooling when we want dry heat for windshield defogger.
Sounds worth a try.
We can compare it with similar data when visible with Xentry NInja or Xentry Passthru
I seen different values between Launch and Xentry, surely Xentry is the accurate one.
Not sure how the E-Class seats compare, but if paying out of pocket, I'd try to get a working seat off of eBay and repair it myself.
. Wow. The E is fine. The ML has similar error for two off the passenger seat motors. It cannot normalize the seat. May need to measure in a few points
I think the part that broke is #20. However, it appears to be discontinued.
Send me your VIN and I'll look up your parts.
Wonder if it is purely electrical. Two error codes are the same seems like too much coincidence
