No Sound from Comand -Ring Break Position 1
Now what? Any insight into what position 1 is or is it not that easy? I have 518 Universal Media Interface module in my data card, along with SAT receiver, neither of which I'll ever use. I think I just need a signal between the amp and the head unit to get sound. Can I put a fiber optic loop in the media interface module and SAT receiver to take them out of the equation?
Not long ago I was interested in coding out the useless DVD with my cReader... so I looked around COMAND for the device map...
Let me try to locate my pics to point you to Device_1. (Device_0 being the head itself).
Here is what I could gather:
MOST
hope that helps
COMAND identifiant
Do you have a good complete scan of your chassis?
Can I ask what scanner you're using? I'm using a Foxwell NT644 you seem to be getting more info. I also don't think I can code anything.
I have the portrait model and now a Landscape version has been released running the exact same Benz database.
It's a $150 unit running a fast version of customized Android with touch screen.
