2016 e63s vibration/shaking at high speeds
Some good wheel balancer like Hunter's Road Force unit has sensors to detect wheel/rim minor out of shape.
Read here : https://mbworld.org/forums/e-class-w...sit-again.html
If you come back to forum, post your location, some forum members may know a good rim repair shop local to you. I went to four shops before I was satisfied with the repair.
If you have a 'square' setup, you can rotate the wheels to locate which rim(s) are the problem (if it is a rim). GLWrepair.
I was driving home through road construction when I heard a loud bang while exiting the 4 lanes area.
I jacked up the front end to reveal free play between 12 and 6 o'clock.
Nothing between 9 and 3.
Great: the steering tie rods and the well hub bearing are fine.
both 1+2 arms usea lower BJ
What's left? The strut plus the two ball joints.
The question then becomes which BJ ??
At 55kMi. I am going to guess both BJ + FWD CTL arms.
We know the forward control arms have a hard life controlling the toe. Does that mean the rearwards arms have it easy.... probably not.
I am thinking this may be my call for front end tune-up with a set of Mevotech upgrades.
I wasn't expecting "MB OEM grade" to poop like that. The next set won't ✌️
+++ 1 or 2 or both:
Right now my 11YR old bushings were equally soft and balanced.
As soon as I replace a single control arm only, it will overpower the weak OEM bushing.
As always fix both sides equal to keep things balanced.
++++ MOOG vs MEVOTECH....
OEM upgrade arms and BJ should be??
