Sponsored by: CARiD
W212 mixed gear without errors
Old Feb 12, 2024 | 07:51 PM
Sereq28's Avatar
W209
I'm trying to fix a problem in w212 om642 with 7g.
the problem mainly occurs after warming up or running longer than reaching full temperature.
After braking, the car starts to shift into Park. but initially you can change gear and keep going.
FInally, after braking, the car puts the car into park and any attempt to change to D or R immediately puts it back into park.
There are no errors in the car. drive select in MRM (steering wheel module) looks normal.
Old Feb 12, 2024 | 08:14 PM
Sereq28's Avatar
W209
I will check this solution in the morning, it seems to make sense. I will see the actual values ​​in ezs.
https://static.nhtsa.gov/odi/tsbs/20...67015-9999.pdf
File Type: pdf
Old Feb 13, 2024 | 04:40 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Did you read the EZS status of your key??
This module has multiple issues including
it use unprotected optical sensors sensitive to dust
it uses marginal solderless pins connections.
Old Feb 13, 2024 | 09:54 AM
Sereq28's Avatar
W209
​​​​​yes, this is a good clue, when the problem occurred, I have an unrecognized valid key in box 297 in ezs. I think this topic will be useful to others.
Unfortunately, I don't know which elements in ezs are damaged.
Old Feb 13, 2024 | 01:38 PM
EZS
EZS fails to revognize your key and causes tranny to slam into "P"...
Is this a "keyless ignition" or is your key inserted in the ignition switch ??
Old Feb 15, 2024 | 09:55 AM
Sereq28's Avatar
W209
the key is physically in the ignition. Unfortunately, I cannot buy EZS with matching numbers. I'm starting to wonder if I should take it apart and look for the cause.
Old Feb 15, 2024 | 09:56 AM
Sereq28's Avatar
W209
