Sponsored by: CARiD
E500/550 ESP (N30/4) 630f00 - Help
Old Feb 25, 2024 | 12:38 PM
blacke550's Avatar
e500
Hey Benz friends,
i am currently going crazy with my e500, for about 3 months the error 630f00 (Star diagnose/Xentry/Gutmann) with a defective ESP appears in the speedometer. the vehicle is then in emergency mode and the engine control light is on. The starter diagnosis did not really help me. The last thing I did was to replace the accelerator pedal, but unfortunately the error occurs again. The car's battery is 2 years old and I replaced the additional battery with an original one from mercedes 2 months ago.
Does anyone have any ideas? Should I repair the ESP control unit?
Edit: adding error code: ISM u113B87 + u012187
Old Jun 20, 2024 | 02:33 PM
blacke550's Avatar
e500
solved: after i replaced the throttle valve (Bosch) the error disappeared
Old Jun 20, 2024 | 05:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Please translate your fault codes into english description.
Its extremely odd the throttle body would be junked. It's usually kept off limits for chaos unless untold things happened to it.
PLS give us a COMPLETE chassis scan to see module interactions. Including both stored + current faults
