Steering angle reset/calibration
1 Post
E 220 Wagon, 2012 mod.
Hi !
I have had the steering rack dismantled and re-installed again, after re-installing i have error code on esp etc. i might have rotated the steeringwheel one turn prior to re-installation.
Is the solution to reset or calibrate the steering angle sensor to fix this, and do i need to do this with Star diagnose ?
Jobba
Jobba
Received 3,448 Likes
MY'14 W212 M276 3.5NA @60kMi
steering angle
Hi !
Jobba
Jobba
Double check you steering "clock spring" did not suffer being 360° off.
Then reset ESP and scan fresh faults.
W212 with electric racks use the steering info to help hold center at highway speed.
If steering feels a bit light and unstable similar to toed-out... the solderless SCM is sleeping on the job.
pierrejoliat (03-04-2024)
1 Post
I have not had the steering wheel itself off the column ant the steeringwheel is centered when driving straight, so the orentation in regards to the clock should be good, so i guess it it just to reset the sensor then ?
Jobba
Jobba
-- Maybe not even reset the SCM because you reassembled everything as it was originally.
-- Reset ESP faults: yes!
-- Test all your steering functions are working as intended after repair. You don't want unexpected goofy surprises.
Scan for all related faults.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,641 Likes
nothing needs to be reset
The W212 FL chassis does not loose any settings during a sanity reboot or extended winter storage disconnect.
Different chassis may suffer amnesia when batteries are disconnected.
Good scanners are useful to diagnose and reset modules.
