Sponsored by: CARiD
W212 2014 E Class - Front Left Airbag malfunction consult workshop
Old Mar 5, 2024 | 02:01 PM
W204guy's Avatar
W204 C Class Coupe
Hi,
2014 W212 E220 CDI.
I'm getting a "Front Left Malfunction Consult Workshop" message and the airbag light. Having read all the forums, it seems a common culprit is the seat occupancy sensor, which people solve with an emulator or new mat.
I borrowed a diagnostic tool and upon clearing the airbag ECU codes, the ones which returned were:
B275296 - the seat occupied recognition of the sensor mat "Front passenger" has a malfunction. There is an internal component fault
B00C513 - the position sensor "Front passenger seat" has a malfunction. There is an open circuit (this one appeared intermittently)
Things I have done:
  • Cleared codes and the above two returned
  • I have tested both batteries - the auxiliary battery is all good and reading 13.2V, the main battery is nearing end of life - 12.5V fully charged and 500/760CCA remaining capacity. On the diagnostic tool, voltage measured by the tool dropped to 11.8V with the ignition on (could this explain the intermittent code?)
  • Checked all the seat connectors and cables. I see no broken wires or damaged connectors, and all are clean
  • I absolutely cannot find a seat position sensor anywhere on the seat rails, on a parts diagram or online
Is this most likely to be the occupancy mat, or should I be looking elsewhere? Could the position fault be caused by the occupancy mat? Does anyone know where said seat position sensor is?
Old Mar 5, 2024 | 02:43 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
seat occupancy
I have never seen this seat sensor.
We know this is seen as a LIN Module by the network.
Working with a good scanner you can further test the status of that sensor. From there decide to replace new/used part.
Old Feb 24, 2025 | 08:27 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Link the following video for future reference
