Sponsored by: CARiD
Reprogram spare key after battery change
Old Mar 25, 2024 | 01:36 PM
Tonyts's Avatar
E Class Coupe CDI 2.2 W212 2011
Mercedes C207 w212 2011 e class coupe
Needed to use my spare key which I know worked 3 years ago. Key does not work at all.
c
Changed Key battery same issue.
Does any one know how I can reprogram the key. TIA
Old Mar 25, 2024 | 02:36 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
no go
Key programming does NOT get lost randomly from flat battery issues, car or fob.
Programming key registration is a licensed locksmith job that requires expensive tools.
Old Mar 25, 2024 | 04:29 PM
JettaRed's Avatar
Veteran: Army
Have you tried inserting the key in the ignition?
Old Mar 25, 2024 | 04:36 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
x2 on MB keys of last 20 years not being user-programmable.
In old cars, inserting key into ignition with switch to ON (no engine run) did work, so I guess it would not hurt to try, but don't hold your breath.
What country? In USA they are about 2 indies, who can handle key repair, when MB USA will force you to buy new key (who in most cases is not available due to Covid)
Do you get any light with new battery?
Old Mar 25, 2024 | 04:40 PM
JettaRed's Avatar
Veteran: Army
In old cars, inserting key into ignition with switch to ON (no engine run) did work, so I guess it would not hurt to try, but don't hold you breath.
My question was not about reprogramming but rather if it worked at all or was it just the remote functions.
Old Mar 25, 2024 | 04:41 PM
JettaRed's Avatar
Veteran: Army
@Tonyts did you put the battery in correctly?
