Sponsored by: CARiD
Mixing coolant with transmission oil caused transmission issues
Old Mar 29, 2024 | 01:41 AM
afyjaslam's Avatar
Mercedes E 250 2010
Exclamation Mixing coolant with transmission oil caused transmission issues
I am using MB E 250 ,2010 year model, I have recently replaced a damaged radiator due to a leak of coolant, which caused a mix-up of coolant and transmission oil. i have changed transmission oil, thermostat, oil filter and gasket.
Car service team told me they have flushed many times to remove the mix, I dont if it is still exist or not. In the meantime, I am using water instead of coolant. I am still experiencing transmission issues, my transmission is rough from 3rd gear. I don't know how to resolve this.
Old Mar 29, 2024 | 03:57 AM
butala's Avatar
W212 facelift
If you have water in your transmission, and you have transmission issues now and before you fix this. That mean your transmission have mechanical problems because longtime run with water.
Go with new transmission or rebuil it. Good luck.
Old Mar 29, 2024 | 09:36 AM
Apexlate's Avatar
E350
If your transmission cooler is in your radiator then this might be your problem:
https://mbworld.org/forums/e-class-w...ure-point.html
Old Mar 30, 2024 | 12:23 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
@afyjaslam Your transmission needs to be rebuild. New clutches, steels, bonded pistons, reman torque converter and the solenoids also need to be replaced.
