M278 Preemptive cam/pigtail maintenance
Hey everyone,
Just picked up a 14 E550 with 14,000 miles. The M278 V8 is quite something! I've researched about the cam magnet/sensor leaking oil into the wiring harness issues on mbworld extensively.
As a preventive maintenance I'm wondering if anyone here ever changed it to the newest revised part for the magnet/sensor and also installed the pigtail harnesses? Is it a permanent solution?
Thanks!
Thanks!
biker349 (05-06-2022)
W222 S550e, C207 E550, W212 E350
Hello fellow M278 owner!
I recently picked up my 14 E 550 as well, and damn! I thought I had low miles at 37,000! Congrats on the gem find...
I have not checked how my current sensors look so I don't know if they are contaminated with oil, but I plan on changing everything as a preventative measure. There is updated part numbers with green O-rings.
I will use this video and change them myself!
Received 1,616 Likes
2014 E550-sold 😩
Congrats on that low mileage E550. How much did you pay for that unicorn? I’ve never had any of those cam sensor issues with my E550 that I’ve had for 5 years and 62,000 miles
Congrats on the great find!
For now, I only installed the pigtails. I'm monitoring to see if oil leakage becomes an issue.
Hopefully, if you update to the latest versions, they won't leak ...
(52) Mercedes-Benz M278 Cam Sensors and Solenoids Replacement (W221) - YouTube
KEY08 (05-07-2022)
2012 E550 sedan 2019 E63 Wagon
Always always swap the old camshaft sensors, specially after 50,000 miles. They will leak creating a nasty mess on the affected side. Pigtails protect the ECU, but not anywhere else that oil falls on. For the camshafts solenoids 100-120k miles is fine.
juanmor40 (01-20-2023)
Thanks!
I could never find pigtails to the sensors until I came across this link on another forum. Although not mercedes parts they work. https://www.ebay.com/itm/17091548172...Bk9SR_zat9q3YQ
Interesting. So, the "kit" listed has pigtails for both the sensors and the magnets, right?
You have put the pigtails on the sensors?
Received 1,483 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
I am confused. The eBay link only lists compatibility for the M278 engine, but I understand the M276, M278, and M157 engine share the same sensor and solenoids.
What am I missing? I may need to order the FCP Euro ones, and find out on my own I guess.
Pigtail for camshaft position sensor(m278)
Pigtail for the camshaft position sensor
Check the part number for your particular model. If the part number is the same the ebay kit will work. All these engines use the same sensors and solenoids I think. That fcp euro kit only has the actual camshaft sensors and pigtails for the solenoids. It DOES NOT have pigtails for the crankshaft position sensors.
These are m278 part #s however if your model part # is the same the listed pigtails will work.
Engine Camshaft Position Sensor
Part Number: 276-905-10-00
Camshaft Solenoid
Part Number: 276-156-07-90
Camshaft Solenoid
That fcp euro kit comes with 4 camshaft position sensors and 4 pigtails for the magnetic solenoids. It does not have pigtails for the camshaft position sensors which are the most prone to oil penetration. You can waste over $230 on it if you want to. I promise you that link I posted in this thread is the only place to get pigtails for the camshaft sensors. That said I could be wrong maybe you can get them somewhere else. If so I could not find them after an exhaustive search.. fcpeuro does not have camshaft position sensor pigtails for a mercedes V8.Mercedes Benz does not have them.
You can get the pigtails individually, no need for the kit. The kit is when you got oil already
I wonder which engine (M157?) uses different pigtails because here they say all recent VVT engines use the same part and cheaper than Ebay.
https://www.fcpeuro.com/products/mer...500156#fitment
$10/piece
or
https://www.fcpeuro.com/products/mer...-2769051000kt1
or
https://www.fcpeuro.com/products/mer...-2761560790kt1
$10/piece
or
or
Non contain cam position sensor pigtails
$10/piece
or
or
https://youtu.be/1A3pZ34UAqA
$10/piece
or
or
Sorry,but you are incorrect.
The point is getting pigtails for the camshaft sensors.Camshaft sensors. Not the magnetic solenoids.You can get solenoid pigtails anywhere. They are $7 at eeuro.com. for oem's. The pigtails are different. The plugs are different. One is a 2 wire pigtail. The sensors have a 3 wire pigtail.
If you READ those links you posted and read what they contain you will see that they are all pigtails for the magnets.(solenoids)You gotta read it.
fcpeuro does not have pigtails for the camshaft position sensors. The sensors are what most often suffer oil penetration. Not the solenoids. On my car non of them leaked. All the sensors did
Non of those links you posted contain camshaft position sensor pigtails.That is the point.You evidently did not scroll down and read what the kits actually consist of. They clearly say 4 pigtails for the magnetic solenoids.
The ONLY place to get sensor pigtails is to buy them in this 8 piece kit on ebay. https://www.ebay.com/itm/17091548172...ug9000b2i00004
My advise to anyone that has these sensors and solenoids is to add these pigtails.All 8 of them. And change all 4 of your sensors to the new ones with the green o ring.It's cheap insurance.
2014 E550 (M278) with 78k miles. I had been looking for cam sensor extensions for some time and was about to try crafting my own, most kits only provided cam solenoid extensions. The set of 8 linked to above was the first I've seen that provided both the 2-pin and 3-pin extensions. On install, I noticed trace oil on one pin apiece in each of the 2 driver-side cam sensor plugs. No oil on other 2 cam sensor plugs or any of the 4 solenoid plugs. Replaced the two failed sensors with new OEM parts from FCP Euro, cleaned affected wiring with electronic contact cleaner thoroughly, and reinstalled all 8 extensions. I'll likely begin inspecting all plugs for seepage every 3 months or so. For what it's worth, I have been asking my dealer service advisor (who has generally been very good) to check for seepage at each of my last 2 routine services. They reported both times no seepage, which means seepage either began only within the last couple months (I believe unlikely), or that they weren't looking very carefully. I advise anyone looking to keep these cars a long time (as I do) to be proactive and check yourself, since no one cares as much about your car as you do.
juanmor40 (02-06-2023)
Yes, new sensors are green ring style. Preemptive replacement of the other 2 is on my short list of maintenance tasks. You're absolutely right about the flashlight. It took a light directly into the harness-side connector to see the minimal (hopeful early) seepage on my two failed sensors. Also, once I pulled the bad sensors, a light into them confirmed seepage at the one pin as well (hard to see directly into sensor plug when still installed in car due to orientation). Thanks again for providing the link.
Even if they are not leaking get them replaced. Once they go, they seep into the harness fast. The first spots are the O2 sensor harness, followed by the ECU. If you wait until the problem is there you are going to regret it. Consider this my last, and only warning.
