Keyless-GO 1 door not working
2012 E350 4Matic with Keyless Go option. This feature has worked flawlessly until.... I hit a nasty pothole and got a Front left (drivers side) flat tire. After tire replace wether related or unrelated the front passenger door keyless-go no longer works to lock or unlock the door. It as if the the door handle sensor is no longer communicating, all 3 of the other handle receivers work still no problem.
Any ideas how I can go about getting this working again? All help appreciated thank you.
1922 Ford Model T / no OBD
You are saying "door" what I would understand the lock is not working?
Or is it handle receiver?
Either way, I would suspect that the impact loosen some cables, so opening the door might be in order.
The lock mechanism by fob or by interior buttons still functions as it should. The door opens and closes with full functionality. Could recommend a location of wires that may have come loose? I will inspect, thank you
W212 MY'14 M276-3.5NA @75kMi
car vs. pothole
without a scanner you don't want to waste time guessing when unnecessary.
Find out what your keyless and door modules report.
I ve just had similar experience driving through road construction: that wasted my 4x front ball joints plus a bent rim.
I am debating about replacement control arms:
- Genuine MB
- Lemforder
- Mevotech
