Audio 20 head unit issue
have tried numerous things like reset , battery , fuses ,and also a different screen to no avail.
so I got a launch creased elite v2.0
and connected after run and clearing codes and running again I got these faults :There are 1 issues for Safety and Security system:
1.The CAN message from control unit "CGW [ZGW]" is faulty.
There are 7 issues for Vehicle body system:
- Timeout error of component "E1m1 (Left headlamp range adjustment actuator motor)" or the component is de-energized.
- Timeout error of component "'E1m2 (Left active curve illumination actuator motor)" or the component is de-energized.
- Timeout error of component "E1m3 (Left light distribution actuator motor)" or the component is de-energized.
- The output for mirror housing adjustment has a malfunction. There is an open circuit.
- Communication with the control unit "Head unit" has a malfunction. The message is missing.
- The mirror dimming of the inside rearview mirror has a malfunction. There is a signal fault or the message is faulty.
anyone tell me if it’s the one thing causes all these faults
Or can any of these faults other than the head unit cause the screen to go off.
and on a side note how do I test for open circuits on mirror housing (any guide or YouTube video)
thanks everyone for putting up with me and this fault
-- It means the display is likely ok and
-- the head is "working" but not sending fiber data over to display module.
Try to access both modules to read live data. This should allow you to further progress.
Look for something obviouslt bad or missing before getting into deeper module details.
and selected the fault with head unit missing .
i clicked it and menu came up
i select control unit/ information and communication/IC - Instrument cluster(A1)(location of fault). But after that the menu is
fuel level , main odometer readingStatus Of Adaptation To Drive Authorization System and few other to dea with dials on dash.
but no audio or head unit in menu .
i have put a few pictures below , it looks like fault is in this module as all the other menus with audio on list say error not connected .
Information and communication
Module with fault
Menu after imformation clicked
Error message for blank head unit
Bottom one is only one that connects rest say error not connected .
Good idle is remove your front panel and check your connection of head unit (audio 20). If you installed aftermarket box for rearview camera or navi, undo it to original to check your head unit. Cable is verry difficult to fail, so hope your head unit not dead. And you only read live data of head unit and screen when it can communicate with center gateway, now it not so maybe you can't access to HU module.
