Sponsored by: CARiD
Help on Headlight Beam Pattern Change (W212)
Old May 5, 2024 | 08:51 AM
kareem_abdo06's Avatar
2016 Mercedes Benz E350
2016 W212 E350
UK style Beam Pattern
US style Beam Pattern
Hellooo, i recently upgraded my headlights to the intelligent headlight system on my 2016 w212, but the beam pattern is like the uk style, is there a way to convert it to the us style beam pattern?
Old May 5, 2024 | 08:57 AM
S-Prihadi's Avatar
You need someone/shop with proper light test machine, and MB Xentry.
They can adjust the height of the beam and the spread to MB standard for LEFT or RIGHT hand drive vehicle.
Since your LED is the 640/641/642 the most advance one, the module must be programmed to also know the correct car level between rear and front.
This type of light test machine
and
Here I am speaking of PROPER and LEGAL beam spread and height.
Not we doing it eye-balling manual version. like oldie halogen.
Old May 5, 2024 | 09:03 AM
https://youtu.be/Xis2xGNQxMU
and
https://youtu.be/ew-Dl79eyhU
These videos shows hot to adjust the lights but not how to convert the beam pattern from uk cutoff to us cutoff. My lights are the full led intelligent lights
Old May 5, 2024 | 09:06 AM
S-Prihadi's Avatar
Dude, there are L/R and Up/Down mechanical adjustment on the light itself.
But you need those light beam sensors to tell you how correct the manual adjustment is and our eyes is not a lumens sensor
The automatic operation must first start with the lights being set as per its market, the manual way. If on a hunting scope it is the ZERO-ing.
Old May 6, 2024 | 12:30 PM
GuestFromTampa's Avatar
W212 E250 BT 4M
While messing with the "Launch X431 Creader Elite 2.0" scanner last week I noticed this option that I assume is a part of an ILS system.
When I Google what it does, I find out that this changes the light pattern if you're visiting a country with a different from your side traffic.
Perhaps this is what will do the trick for you.
Old May 6, 2024 | 01:57 PM
S-Prihadi's Avatar
Damn, I almost forgot that the Instrument Cluster MENU has adjustment of the headlight for Left or Right Hand Traffic.
Try that and see how......
Old May 6, 2024 | 02:02 PM
I dont have that option, initially my car did not have the intelligent light system and we installed it, will try to code in that menu, can you try that option in the menu to see if it changes the beam or flattens it
Old May 6, 2024 | 11:16 PM
butala's Avatar
W212 facelift
By your photo, sure you've intelligent light. So this menu in IC not avaiable for left hand or right hand traffic, that mean in your country this menu is disabled. You can ask some one who has xentry or vidiamo, sure you can change this. Left/right hand traffic can code via your headlight module.
Old May 7, 2024 | 09:43 AM
S-Prihadi's Avatar
My car is out of action for the next 2 weeks. battery is out.
When I can, I will try to see what happen if I do use RIGHT HAND TRAFFIC ( USA ), instead of current LEFT HAND TRAFFIC ( UK & many of Asian countries )
If you only bought the ILS headlight and the car did not come with it originally, you need to code the gateway Front SAM or Rear SAM ( I am not sure ) to let it know that your car has ILS 640/641/642, otherwise
you can't use it to its maximum potential.
Look for BenzNinja and while at it, get the Xentry from him as an IMPORTANT TOOL. He can code all these ILS stuff for you.
Old May 7, 2024 | 09:47 AM
Does this disable intelligent light system features or give any errors
Old May 7, 2024 | 12:57 PM
JettaRed's Avatar
Veteran: Army
I would reach out to @BenzNinja . I'm pretty sure he can help with this, as well as just about everything else that needs to be done with XENTRY.
Old May 7, 2024 | 01:03 PM
I would really appreciate it if you can reach out to him
Old May 7, 2024 | 01:06 PM
JettaRed's Avatar
Veteran: Army
Go to his website www.benzninja.com
I will send him a link to this thread, as well.
Old May 7, 2024 | 01:21 PM
Great thankyou
Old May 7, 2024 | 10:52 PM
butala's Avatar
W212 facelift
Yes, can disable or enable intelligent system features. And some time, if the headlight has mechanical issues and don't want change new headlight, somebody disable some features to ignore error code, but I'm not recommended that.
Old May 8, 2024 | 04:29 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Ir-regardless, the intelligent lighting system was not approved for US use, I would doubt there's a US light setting vs. the Euro setting since it was never an option here. Also, tourist mode just changes the lighting based on which lane you are driving in, in a left hand drive car if you want to drive in a left lane country or vice versa.
Old May 8, 2024 | 04:30 PM
Originally Posted by pierrejoliat
Irregardless, the intelligent lighting system was not approved for US use, I would doubt there's a US light setting vs. the Euro setting since it was never an option here. Also, tourist mode just changes which lane you are driving in, in a left hand drive car if you want to drive in a left lane country or vice versa.
I only wan tto change the beam, not the country of the lights
Old May 8, 2024 | 04:32 PM
Yes, i got that, since the ILS was not an option in the US, I doubt they would have coded a beam pattern difference from the Euro. If in fact it's possible, Benz Ninja would know
Old May 8, 2024 | 04:37 PM
Alright, will update you once i take the car to a coder. The goal will be to change the beam shape to us style with keeping intelligent lights enabled. Not us coding, but us shape as i have shown in the pictures above, so i wont blind others
Old May 8, 2024 | 04:42 PM
I understand clearly what your after, you need to understand what I'm telling you, ILS was not ever approved for the US market, no US beam pattern is programmed into ILS /Euro I don't believe from my past research, Tourist mode only adjusts the lights from left lane driving to right lane driving
Old May 8, 2024 | 04:44 PM
Old May 8, 2024 | 04:46 PM
Yup, that is what i am targeting, becaus in the current setup it is blinding people on the opposite lane. But i want to be sure if i enabled that menu and changed the lane, will intelligent light system be disabled? We need someone with a 2016 e class and intelligent lights thta lives in europe to test it
Old May 8, 2024 | 07:23 PM
JettaRed's Avatar
Veteran: Army
This is what is confusing to me. Both of my cars (2014 C350 and 2015 SL400) are imprinted with Intelligent Light System on the headlight. Both are US-spec cars. I will ask BenzNinja what that means.
2015 SL400
2014 C350
Old May 9, 2024 | 12:04 AM
S-Prihadi's Avatar
Yes yes, I remember now. ILS to European full capability is not US approved.... poor soul.
Must code a lot....
Old May 9, 2024 | 12:12 AM
S-Prihadi's Avatar
2015 SL400
2014 C350
It is MB fault.
They lack of creativity to call those features
The LED LED ILS 640/641/642 is called Dynamic LED. Which is also Intelligent Light System aka ILS
So Dynamic LED is supposedly the best there is.
I too get confused with MB brochures or sales video, as they are not the same as WIS.
So WIS is a better name technically.
So US market probably get Code 642, a dumb down version of INTELLIGENT .... he he he he.
See full data in zip for ALL cars and Code 640/641/642 & Auto High Beam code 628 or 608
File Type: zip
