Sponsored by: CARiD
[Variant Coding Launch X431] Close Trunk With Remote
Old Jun 26, 2024 | 05:19 PM
CLKx430's Avatar
14 E350 wagon
Post [Variant Coding Launch X431] Close Trunk With Remote
How to Close Trunk With Remote on s212
  • System Selection
  • PTS - Power Tail gate
  • Always backup before changing code
  • Variant Coding
  • Scroll to
  • Control Switch_1_vc
  • PLZ Always backup before changing code
  • No. 001 Switch Remote Key Closing
  • Change to Active
  • Select ‘Write Coding’ and follow the prompt instructions.
Bouns:
I’m not a fan of holding the trunk close switch on door
so i changed mine to auto close with door switch.
  • Variant Coding
  • Scroll to
  • No. 004 Switch Automatic Closing via Door switch
  • Change to Active
Don't forget to backup you code!!! Thats your fail save if something stops working!!!!
Old Jun 26, 2024 | 05:31 PM
W205C43PFL's Avatar
  • System Selection
  • Variant Coding
  • Scroll to
  • Change to Active
Bouns:
  • Variant Coding
  • Scroll to
  • Change to Active
Interesting how many hidden features this palm size machine has.
Old Jun 26, 2024 | 05:43 PM
CLKx430's Avatar
14 E350 wagon
its money well spent
Old Jun 26, 2024 | 06:42 PM
W205C43PFL's Avatar
Glad to hear it
Old Jun 27, 2024 | 03:35 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
GREAT programming!!
This is great find: THANK YOU!
This a perfectly written research and instruction guide. This enhancement is a must-have
The module is PTG (not PTS).
I recoded both #1 + #4
One problem.... now when I use keyfob to open my trunk, it recloses automatically up+down right away.
This has to do with #1 option.
Its like the keyfob trunk-buton is now a "close trunk".
I am going to back track on #1 "inactive" until further testing.
Old Jan 8, 2025 | 01:03 AM
dreamer1's Avatar
Wii it work on my W213 E200 2017?
Old Jan 8, 2025 | 03:48 AM
you'll need to poke around a little
​​​​​​Mercedes likes to shuffle things frequently.
Be sure to dave a backup copy of settings in case parameters don't go smoothly with possible corruption (unlikely but possible and expensive).
Old Jan 8, 2025 | 10:41 AM
FLASHBACK's Avatar
2013 E250CDI BlueEfficiency 4Matic
CaliBenzDriver Did you ever solve the remotebutton open/closing glitch?
Old Jan 8, 2025 | 05:23 PM
TRIALS 'N ERRORS....
Unfortunately nope, I back tracked because I try to keep my modules in mint-condition to rework with unstable networking issues.
I want to limit additional variables to suspect screwing things up.
Tweaking programmable firmware is awesome but proceed with caution. Go ahead do more poking and testing, there's more room for improvements.
Old Jan 8, 2025 | 06:07 PM
JettaRed's Avatar
Veteran: Army
Does not work on my 2015 SL400. My PTS module is the parking (Parktronic) module. I tried to find the controls somewhere else, such as the rear SAM and could not.
Old Jan 9, 2025 | 07:54 PM
dreamer1's Avatar
Thank you for the reply.
I am in trouble with a turn signal coding(flickers twice) and could not backup. (OLC_turn Signal_model)
I tried to restored the setting back but did not work.
Is there a way to solve the problem?
Old Jan 9, 2025 | 08:18 PM
can you picture the exact screen and data you need help with ??
Old Jan 9, 2025 | 09:12 PM
dreamer1's Avatar
Thank you for the quick reply.
I will send you the exact screen with my modification once I return to my house in the evening. (Currently living in South Korea)
This really gives me headache, and hope it will get recovered.
I have another question.
I did perform backup before writing codes, not the above one but other codes, few days ago.
Is there a way to recover the previous state to where I performed last backup before coding?
I dont know what it means 'backup' before writing code. (Whether it is just for that particular menu or whole coding itself)
Thank you so much.
Old Jan 10, 2025 | 12:55 AM
Thank you so much.
I think the "backup" scope is limited to the data on the current screen, excluding any data outside.
What backup you don't have, you can not restore
Old Jan 10, 2025 | 01:19 AM
dreamer1's Avatar
I see. When the device is power off, the backup is gone right?
Old Jan 10, 2025 | 01:30 AM
NOOope... the backups are saved inside SD-Card
Old Jan 11, 2025 | 08:52 AM
dreamer1's Avatar
Fortunately, the problem has been solved!
Thank you for everything!
