Knocking Noise on cold start
The cyclical knock says it's from a single cylinder.
It sounds like a rod knock.
Eventually this will get flagged by CEL as a MISFIRING fault code. A degraded cylinder with working ignition.
Are you familiar with oil analysis? You can collect an oil sample and get it analyzed for wear particles.
> PLAN B :
is a viscosity upgrade + drive into the groung gently or shortly.
Have a look at cylinder walls. Some of these engines suffer from oiling issues.
