Sponsored by: CARiD
Co driver/ passenger ORVM Puddle light.
Old Jul 25, 2024 | 03:52 PM
Spruze's Avatar
Mercedes E250 W212 Diesel- OM651
Hi all,
My E250 2014 Passenger side ORVM puddle light sometimes work and sometimes it doesn’t. Sometimes when it doesn’t work I give the ORVM some taps and it works.
What could be the problem? If it’s the bulb can someone share the part number.
Old Jul 26, 2024 | 06:03 AM
S-Prihadi's Avatar
Originally Posted by Spruze
Hi all,
Dont use the original 5 watts version of the bulb, use 3.4 watts from Honda. If door open too long and often, the bulb reflector housing will be burnt.
Buy and use this one : https://www.hondapartsnow.com/genuin...8-ga7-701.html
See how much cooler is the 3.4 watts version
Oops, you are speaking of MIRROR and not the door. Dang. Sorry.
But this is good info for the door and if the mirror also uses 5 watts incand bulb, you swap it for 3.4watts one.
Old Jul 26, 2024 | 06:19 AM
S-Prihadi's Avatar
It is the same 5 watts as the door puddle light. Even on mine, as per EPC. Item #35
If I do same teardown like below, I guarantee some of the plastic will crack , my fingers are not good with fragile plastic locking tabs
Old Aug 9, 2024 | 02:47 PM
Spruze's Avatar
https://youtu.be/y8c1atfGKpI
Thankyou man! Yeah same even I am kinda afraid to tearsown the ORVM 😂
Thats why I just try making it work by tapping the ORVM slightly
