Only had oil changes, air filters replaced. Now it's mine. I'm gonna replace the spark plugs and put some fuel injector cleaner in. Should I have a shop do transmission fluid change? I called one shop and they said it's not serviceable so not sure, then I had another shop quote me $900! Any other suggestions? Running fine.
Best,
Scott
Running fine.
Best,
Scott
Scott, other suggestions are to replace engine oil at 5kMi ( not 10,15 or 20k).
also renew 4x leaky Cam Sensors to preserve $10k harness job.
Thermostat + coolant
belt kit,
chain tensioners,
PCV + HPFP roller
Brakes pads/rotors, flush, lube slides,
Front/rear end suspension refresh
engine/tranny mounts
plugs + boots + (coils)
air filters
(batteries)
