Sponsored by: CARiD
2010 E63 front camber adjustment - Anyone??
Old Aug 8, 2024 | 10:20 PM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
Has anyone had any luck or experience adjusting front camber on a 2010-2011 E63. It is different than all w211 and all other w212's. I have searched this forum and cant find anything specific to this. The control arms everyone raves about are for 2012-ups and the adjustable bolts are for 09 and older. It seems like there is no adjustment possible unless i do something totally custom. I have negative camber on the right front that is so bad its noticable to the naked eye not just the alignment machine. I have already tried a new strut with no change.
Old Aug 8, 2024 | 10:28 PM
richvegas's Avatar
Way negative
In spec
Old Aug 9, 2024 | 06:02 AM
ygmn's Avatar
2015 E400 Sedan
see your other thread in AMG section.
Old Aug 9, 2024 | 10:21 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
It might be time for new springs, I'm thinking about that myself on my '13 with 101k miles, just had it aligned, the "toe" is now fine but it's sagging like yours a bit.
Old Aug 9, 2024 | 01:47 PM
S-Prihadi's Avatar
Is your chassis W212.077 4-matic with M156 engine ?
If so, all you need is either new arms or the correction bolts.
Show me your alignment report
Old Aug 9, 2024 | 01:53 PM
richvegas's Avatar
It is not a 4matic, there are no m156 4matic w212 e63’s, these control arms do not use or fit the adjustment bolts.
I will print up the alignment report next time I bring it to work.
I did check out the KMAC site and that will probably be the way to go.
Old Aug 9, 2024 | 01:57 PM
S-Prihadi's Avatar
oops sorry, W212.077 it is not 4-matic indeed.
You did not confirm yours being a W212.077, if it is, read below : Correction bolt is available as per EPC.
