CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,775 Times in 4,764 Posts
Standard interval deliver standard experience very well.
The day oil star Shell Rotella gets rated API SP, I'll be driving it.
With new MOD-2.0 Motul 5W40 oil: engine ran balanced silky strong and smooth for at least 2500Mi unlike ever before - Old oil makes engine vibrate/shake when stuck rings are unsealed.
Thin oil does save gasoline... "more miles for less"The day oil star Shell Rotella gets rated API SP, I'll be driving it.
pierrejoliat
close
- Join DateMay 2012
- LocationPepper Pike Ohio
- Vehicle(s) I drive24 GLS580 '23 E450 4matic 12 E350 4Matic
Liked:1,555 Times in 1,031 Posts
I just got back from a road trip to Arizona, 2100 miles each way, I changed the oil before I left and when I returned home, it was golden going in and dark brown on return, my average speed was 79 mph, I stayed in hotels in site of the freeway so no city traffic to lower the average, RPM's were between 2350 and 2750 during the drive, so that may have effected dirtiness and loss of viscosity which was obvious. I have also changed the oil on my two benz's at 5k miles since new 11 and 12 years respectively, I also use 10W-40 since new and have no engine leaks yet, my '13 has 101k now. I worked at Lubrizol for five years or so back in the '80's in the oil testing lab, never saw a formulation make it past 5k maintaining viscosity, ever. but I'm sure synthetics have improved over that time at least somewhat.
dmatre
close
- Join DateFeb 2003
- LocationCharlotte, NC
- Vehicle(s) I driveHad: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Liked:339 Times in 191 Posts
Having worked in oil testing, I think you'd find this guy and his channel quite interesting...
https://www.youtube.com/@themotoroilgeek
Quint22
close
- Join DateJun 2022
- LocationWA State, USA
- Vehicle(s) I drive2014 Cummins, 2014 E250 Bluetec
Liked:328 Times in 234 Posts
Guess it depends on what engine and oil. Seems the gassers are pretty quick to need oil changes. My diesel truck Ive done 15k intervals with dyno 15w40 oil from new and it has 190k miles on it now. My e250 om651 not sure what interval was before but I got it but now I usually do about 7-8k miles depending. The sprinters with the same engine can go longer but also have a larger sump.
Never done a OA on any of my vehicles so just hearsay on my part and the results Ive scene. If my OM651 didnt have the emissions stuff on it I would run a standard diesel oil and for longer between changes.
pierrejoliat
close
- Join DateMay 2012
Yes, he's good, I saw his viscosity breakdown video and thought it was spot on.Originally Posted by dmatre
Having worked in oil testing, I think you'd find this guy and his channel quite interesting...https://www.youtube.com/@themotoroilgeek
