Sponsored by: CARiD
I added a little too much oil on the last change...
Old Aug 16, 2024 | 02:05 PM
jtb33's Avatar
2007 GL 450 (former) and 2012 E550 Coupe
It's an E550 Coupe, so it uses 9L of oil normally. I actually put in around 10L. The dip-stick has oil to just above the end of the plastic tip - just touching the braided wire portion.
Is that going to be a problem where I should extract some, or is that not enough to really matter?
Old Aug 16, 2024 | 02:09 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Suck some out.......
Old Aug 16, 2024 | 04:35 PM
TimC300's Avatar
I would extract some oil until it is showing at the proper fill level.
My W204 manual says to fill it so its in the middle of the Min-Max and there happens to be a dot on the dipstick there. I used to fill it to the Max mark until I read the manual where it says from min-max is 2 quarts, so filled to the max line is technically 1 quart over filled. Thats at least how I look at it.
Just search "oil over filled in engine", plenty of reasons not to do it.
Old Aug 17, 2024 | 11:57 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
It matters, if you have a vacuum extractor, use it. if not, you can pull the oil filter and wipe out the oil from the filter chamber a few times after replacing it and restarting for a few minutes.
Old Aug 17, 2024 | 01:25 PM
JettaRed's Avatar
Veteran: Army
You can use a cheap 12V fluid pump or get a Mityvac or equivalent extractor, but definitely do not over fill.
Old Aug 17, 2024 | 04:01 PM
jtb33's Avatar
Thanks. I removed about 1L from it and on the dip stick, it's just above halfway on the plastic piece - thanks.
Old Aug 18, 2024 | 03:16 AM
BenzV12's Avatar
W212 FL
Good job, I have not searched the facts but I was informed that overfilling is just as bad as underfilling (the latter word doesn't exist lol )
Old Aug 19, 2024 | 03:41 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
yeah, overfilling can blow seals and stuff.
Old Aug 19, 2024 | 05:01 PM
JettaRed's Avatar
Veteran: Army
Actually, the problem with overfilling is that if the sump/oil pan is too full and the crankshaft or piston rods contact the oil, they can froth the oil into a foam, reducing oil pressure and the ability to lubricate necessary parts. That includes causing insufficient oil (oil starvation) to the pistons, cylinders, and turbo shaft. In other words, you can destroy your engine with too much oil. However, going over the top marker on the dipstick a little is unlikely to be considered dangerous overfilling.
Old Aug 19, 2024 | 05:45 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Old Aug 19, 2024 | 06:31 PM
jtb33's Avatar
Good info - thanks!
Originally Posted by juanmor40
Yeah, I've seen that one - but we're talking about a high-performance bi-turbo V8... that's a Lada engine; lol. Further, he runs it like that for a minute each time.
Hardly apples to apples and a poor use-case for a car that will actually be driven with over-filled oil.
Old Aug 19, 2024 | 06:55 PM
JCM_MB's Avatar
Good info - thanks!
The fundamentals are identical. Either for 1 cylinder or 16 cylinder the principles are the EXACTLY the same. Being inline, star-design, W-design, V-design, etc. are ALL the same. That is how I learned during my mechanical engineering studies.
Old Aug 19, 2024 | 07:10 PM
jtb33's Avatar
I don't disagree about the fundamentals from the video, but what he shows is simply what happens when you overfill it with oil and run it for a few minutes at a time... not when you put a load on it and drive it down the highway for an hour in stop-and-go traffic. They physics and dynamics are going to be very different, I'd think.
Old Aug 19, 2024 | 07:55 PM
JCM_MB's Avatar
The point is the crankshaft is effectively blending the oil, and creating foam. As long as the foam NEVER comes into contact with the oil pump pick up tube everything will be fine since the oil pump will ALWAYS see pure liquid oil.
Once the foam makes it into the pump, the pump can no longer raise the pressure as designed since the "fluid is compressible". If the pump fails to raise pressure, the flow of oil within the conduits is compromised, the bearings can starve and the rest is history.
That is the whole point of the video. Everything else what anyone in a laboratory will do: cover the maximum range of the variables being studied to archive full set of results.
