Failed Emission Test (high HC) M272 E300
I learnt a new WHAT IF yesterday, but will need to test again once Tesna has replaced the leaking seals of MAF lower Air Elbow and other component with issue.
Tesna, you were wondering how the MAF secure itself on the Air Elbow, that small steel U latch is it. Since this is vacuum based system of NA engine, it does not use much securing method like my
turbocharged intake manifold system which is 0.8 BAR positive at boost.
M272 vacuum pump small port is interference fit. There is no small bolt. I dare not pull it out to inspect it
That small port has lost its membrane for sure, as I can't get it to hold vacuum pressure using vacuum hand pump.
The small hose connected to it also torn, hence oil spits out of that baby port.
Emergency Fix, using 4mm x 9mm silicone vacuum hose
Here is the WHAT-IF part I was thinking since last night.
Vacuum pump sucks air from enclosed space, like vacuum actuators on the engine and brake booster.
Whatever air get sucked into a vacuum pump, it must be dumped out too. The vacuum pump dumped out the air to the engine crankcase, via its mounting spot at the camshaft end Bank 2.
If HVAC type general purpose vacuum pump, it dumps out air to the atmosphere.
Why my thoughts shifted to the vacuum pump ?
Because yesterday I was trying to read Tesna M272 crankcase vacuum pressure and I hardly can get -1 millibar, where my M276.820 can do -36 millibar.
This test was before I found out that the small hose of vacuum pump was torn.
Our engine PCV system sucks air out of the crankcase, but the air is from piston blow by, it is not fresh air.
In Tesna's M272 vacuum pump leaking hose scenario , it may also suck some fresh air and naturally dumped it back to crankcase.
I am wondering, how much negative crankcase pressure improvement will I read ?.... when the vacuum pump leaking issue corrected.
vacuum pump, will get the full vacuum pump assembly, just for peace of mind. If that port is not holding vacuum properly then the vacuum system connected to that port also not working properly then? since it burst out oils instead sucking air...
I was researching about the secondary air valve.
It seems it is common issue the valve can fail. If it failed, it can introduce exhaust gas to the secondary pump and damaging the pump. I was trying to inspect it for carbon deposits on the bank 1 valve, but failed to open up the hose (tried with all my ability but seems stuck). bank 2 no problem opening and it seems clean. Trying to inspect the hose intake from the secondary air pump to the air filter box that one seems clean tho, although I do smell exhaust smell on it. (or maybe its the silicone grace applied yesterday?) Tried to block it with plastics but the plastics does not get bulge/larger.
Regarding the air flow secondary air system code yesterday I tried to plug the air supplying the pump so that code is expected. I thought it only turned on once during cold start up, I experimenting that whether plugging the hole will fix my fuel trims or not
) once II heard the pump is running (again) when it was plugged I immediately switch off the engine
I cannot find the air control valve in the local market , perhaps needs to order from FCPeuro again
and boy it is quite expensive. Can I delete it? I can order custom blank metal plates to cover the hole.. Can I code it out the air injection system?
) once II heard the pump is running (again) when it was plugged I immediately switch off the engineI cannot find the air control valve in the local market , perhaps needs to order from FCPeuro again
and boy it is quite expensive. Can I delete it? I can order custom blank metal plates to cover the hole.. Can I code it out the air injection system?Good idea to delete. W212 E200 with M271.8 EVO for Indonesian market, they do not install Secondary Air Injection system.
Since the baby Lauch seems to be able to code it out...even better
Turned on the engine, no exhaust noise were heard. Then I actuate the valve to open using launch, and it still actuates :O exhaust noise then heard from the valve (and quite loud too). So this valve still somewhat works
Anyway I'm still planning to delete it. Maybe there's still small leak (since the valve does not hold vacuum) it's the only remaining explanation why on bank 1 LTFT is positive. If deleting/replacing the valve still giving me positive LTFT I'm going maaaaddddddd
maybe I'll just replace the car
anyone with M272 engine share their LTFT results? maybe it's their nature........
That means the main valve is minor leaking and membrane a bit torn. That is why we keep loosing vacuum pressure when testing with hand vacuum pump.
When the MAF Air Elbow seal fixed, your fuel trim should improve a bit.
Can the seal alone be ordered ?
But then, nothing else explain the imbalance fuel trims between bank 1 and bank 2, I replaced almost everything except... maybe ECU? Or maybe just live with it. Set the fuel quantity to lean out every time I want to pass emission test
Btw, the seals between throttle body and MAF on order, it will be replaced soon.
shiny new parts
new intake manifold but I get this now...
You still have minor intake/vacuum leak at the MAF's lower elbow orange seal.
The 02 sensor front ones still old one.
I think the mechanic mouth blowing power is not as powerful as my smoke machine
,,,,BTW,
Have you ever tested the fuel pressure at the mechanical valve at the end of the fuel rail ?
See below :
Reading fuel press here reads the NET pressure the injectors are provided with.
Reading at the fuel filter electronic fuel pressure sensor is a GROSS pressure.
I want to see NET fuel pressure.
This thing is like a regulator/reservoir of some sort.... I wonder how important this one is.
I looked at the WIS, I can't find any technical information or function about this 17/1 .
I would think it acts like a mini pressure/volume regulator. You know in a fresh water pump, we have those 5 liters air tank, which is actually water filled to 50% and the other 50%
is pressurized by a membrane typical at 30 PSI of air.
)Of course I never check the fuel pressure on the rail mechanically, since I don't have (any) tools
) But I dont think I have problem with fuel delivery as no hesitation at WOT, the power is there.And after replacing the vacuum pump, I still have the tumble flap code
it is current and stored, not stored only so it is a current issue. I can hear the flap actuates if I do tumble flap actuation test. Vacuum line contaminated with oil? or the replacement hose is too bendy hence partially blocking the flow? or somehow the sensor disconnected? But the secondary air injection valve still actuates....so the vacuum still there somehow.I cleared the codes, lets see tomorrow the code comes back or not.
Are those 2 sensors new with Pierburg unit ? Or the old one is being transferred to the Pierburg ?
If you can see that the actuators are moving, that means it is moving.
Could be as simple as bad contact on the connector/s to the sensors or loose, not plugged in well.
Access it, inspect the connector female pin.... open up too much or not and clean it with CRC contact cleaner.
https://www.tokopedia.com/chemical-m...lse&src=topads
My friend's M271.8 EVO engine after 60 days engine being out/removed, I have to clean with contact cleaner many sensors connector as they
gave out DTC...from bad contact.
When I was into tuning my Audi, I think the stock FPR was 3 bar, and with a tune I had to use a 4 bar FPR to deliver more fuel. Some tunes required both bigger injectors and a 4 bar FPR.
There is only 1 port to test fuel pressure at the end of the fuel rail at Bank 1 - Right Bank., which will be reading both 17/1 reservoir doing its work and averaged out.
It can leak, one member here asking :
There been 2 cases where M276 3.5NA has intermittent bad to mild misfire come and go and it took ages to troubleshoot. You may remember them.
Both of them basically has "contamination" at the fuel rail. One is a US member, the other is from Holland.
This is what I want to check with Tesna's M272, at the least I will read fuel pressure at the rail first as it is easiest.
I think I know the proper name for the FPR, it is pulsation damper. The FPR could be a direct literal translation from German to English.
Pulsation damper for racing : https://raceworks.com.au/fuel/pulsation-dampers/
. I can feel the difference on driving, the engine is not as responsive as before I have that code. Maybe I'll replace the hose with longer one so it does not bend so bad. Btw, can I clean the vacuum lines by spraying brake cleaner? is it safe for rubber and plastics?Pak @S-Prihadi, regarding the sensors, there are 3 actuators right? 1 is the swirl flap for both banks (in the center) and the other 2 is the intake runner short and long. Which one is the charge movement flap? Is all sensors located on the same location?
Regarding the FPR, thanks for the input @JettaRed , I'll leave it to the expert Master Surya
EDIT: add video
I thiink this is the vacuum cable supplying vacuum to the intake manifold. contaminated with oils and very loose..... very easily disconnected.
Now can go back on track on finding the cause of positive LTFT
or perhaps I need to do some rest. well at least I have (a lot) fresh new parts now.
Fuel consumption is quite good too, on heavy foot I get average 9 ishL/100km on the highway. perhaps if I baby it can get better. Engine power and response also very good, no pinging/misfiring, no hesitation, no noticeable problem what so ever.
So do I need to close the book of getting LTFT closer to 0%? or do I need to check on another things? seeing LTFT got improved when the engine under higher load, do I still have vacuum leak somewhere? or its not vacuum leak? what else should I check?
As long as you can pass your emissions test and there a no DTCs, I'd put the Lufi away or change the display to not show LTFT.
