Sponsored by: CARiD
Coilovers
Old Sep 3, 2024 | 02:40 PM
Andyanth's Avatar
E350 Sedan RWD
Coilovers
I would like to lower my 2010 e350 RWD about 2".
My mechanic says that anything more than an inch will have a serious impact on tire wear and alignment.
I would appreciate opinions on this.
Old Sep 3, 2024 | 08:31 PM
tesna's Avatar
W212 E300 2010
the camber will be negative so the inside will wear out faster. However I always loweerd all my cars and the tires usually last for 50k kms for me. Its enough compromise for me
Old Sep 3, 2024 | 09:19 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
If you lower, look for Kmac camber/caster kits to achieve proper alignment specs.
Old Sep 4, 2024 | 09:23 AM
Senecat's Avatar
1983 Nissan Shltbox
Parts are cheap. Slam it to the ground.
Old Sep 5, 2024 | 02:52 PM
Andyanth's Avatar
E350 Sedan RWD
Thanks for the response.
I'm surprised at the cost of Kmac kits.
Do you know of any more inexpensive options?
Old Sep 5, 2024 | 09:26 PM
Andyanth's Avatar
E350 Sedan RWD
Pardon my ignorance but why do some camber kits consist of adjustable bushings (such as the Kmac kit) and some consist of just bolts/nuts and a washer/ shim looking item (at a considerably less cost)?
Old Sep 6, 2024 | 11:10 AM
dmatre's Avatar
The bolt/washer you are referring to are commonly known as ‘crash bolts’, and are used to try to reach factory spec if the car has been in a crash, and the frame/suspension repair has been ‘less than perfect’.
The kits with offset bushings are designed to have far more adjustment, and typically have updated bushings for longer life.
In this game you have to pay to play. I cant remember a single time in my life thinking ‘gee, I wish I bought the one that wasn’t as good as this one’.
Old Sep 8, 2024 | 02:09 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
re lowering 2", cars with the 'sport' package (majority of post-facelift w212s in the USA, not so sure about pre-facelift), are already lowered about 1.5". drop that another 2" and you'll be scraping body parts on driveway lips and such. a fast looking car that has to slow down to 2 MPH to carefully step over a railroad crossing is, IMHO, a joke.
Old Sep 8, 2024 | 06:20 PM
Andyanth's Avatar
E350 Sedan RWD
Thanks for the response. I appreciate your opinion. On a somewhat separate note, Anyone have any opinions on camber plates vs adjustable bushings? This is just for lowering purposes. Car is a daily driver. No track.
