Front strut mount location
Received 4,591 Likes
I use loctite blue for the 2 big bolts of the caliper. To be safe.
Only use blue, never red one.
The following 2 users liked this post by S-Prihadi:
MBNUT1 (09-16-2024),
pierrejoliat (09-16-2024)
Received 1,028 Likes
2010 E350 4Matic
2014 Cummins, 2014 E250 Bluetec
The heat is not from the strut bearing spinning at high speed.... it's from the engine heat -
A basic cheap grease evaporates to leave behind sticky glue like residue...
The transformation at 60kMi was pretty amazing and worth the troubles.
Note during new strut top installation... the new plastic bearing enclosure needs a little rework as well. It sits over a metalic tappered shaped but is way too small (stress to the plastic)... I don't have picture handy.
Received 3,712 Likes
MY'14 W212 M276 3.5NA @60kMi
STRUT MOUNT ENHANCEMENTS....
Let's not mixup everything... back to the front strut topic - Where this stands is:
Use new strut bearing as-is or upgrade to high-temp grease that will survive engine 200°F heat without evaporating into glue.
Regarding the assembly of new Febi plastic bearing enclosure onto tappered strut shaft bushing:
plastic centered over a tappered cone.... uncle Murphy!!
Rescue-scuba me can't ignore Uncle Murphy' in nearly compatible parts without proper QA checks.
these plastic niples need serious filling
Shave the niples to the point plastic assembly can seat evenly all-around on the metal holder.
No expension stress should split cracks into plastic... no thank you
I don't know how good is the MB part.
The new Febi is 1mn off!
No problem once it's filed down.
The suspension spring needs to seat evenly: that's absolutely non-negotiable!
this is the mother of all bushings...
Once the rubber as soften precision is history!
The strut bushing guides the top of what is a triangle formed with both lower control arms.
We recognize control arms bushings as being essentials and so are the struts bushings.
Smooth & precise steering:
