Sponsored by: CARiD
E350 AC Issues
Old Oct 4, 2024 | 01:34 PM
Scarlett Inman's Avatar
E350
E350 AC Issues
I'm having issues with the AC. I took the car to the dealer to have a software update done hoping it would fix the problem. I have a few issues.
1. When I press the AC button to turn the AC off and just blow regular air, it does not turn off. The only way the AC turns off is when I turn the system off all together.
2. When we drive the car for a bout 2 hours the AC stops working. No air is blowing but it sounds like the air is blowing but nothing. I turn it off a few minutes and turn back on and it works for maybe 5 to 10 minutes and have to do it again.
Other then that, the car is GREAT!! It only has 84K miles on it. If you have had this same issue, please let me know what fixed the problem. My family is wanting me to trade the car, but I LOVE it!! The last benz I had was the same year and was an E350 and didn't have this issue...
HELP!!
Scarlett
Old Oct 4, 2024 | 02:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
DIRTY AIR FILTRATION
HELP!!
Scarlett
Your No1 entry is by design - Not an issue.
Your No2 is coil freezing up because of limited air circulation.
Simply replace $10 cabin filter or remove it for the time being.
You don't need to get you entire A/C system components replaced one by one or trade in your excellent car. It needs timely maintenance for each systems.
In the maintenance Dept: replace engine oil at 5000Mi. not when the display says it's service time.
Old Oct 6, 2024 | 08:48 AM
Jeedie's Avatar
S212 E300
Interesting, I recognise number 2, the AC blocking up after ~2 hours of driving, depending on weather conditions. If I switch of the AC compressor (the AC button unlit) and leave the interior fans running for ~10 minutes, it seems the coil has ample time to de-ice. If I switch the AC compressor back on, it will happily cool the car for another 2 hours. Oh, and I've very recently replaced my interior filter and there is plenty of air circulation.
I've checked the temperature of the evaporator with my launch tool several times when this occurs. I can't find a temperature reading below zero, even though the system acts like a frozen evaporator. From some forum posts, this situation might happen when your system is low on coolant in the AC system. I've not yet tried to refill the system to check if this cures the issue.
Old Oct 6, 2024 | 06:54 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
You might check the evaporator drain line to insure its working fine, you can also buy a can of evaporator cleaner. Mine had a similar problem and I did both at the same time so don't know exactly which one solved it, but the cleaner cleaned out the drain tube. I did not have a musty smell yet when I cleaned it. Also, I should ask, do you run it set to LO and use a low fan speed? Or on RECIRC continuously?
Old Oct 7, 2024 | 12:26 AM
Arrie's Avatar
You can lose cooling also if the system is over pressurized, i.e., too much refrigerant in the system. If this happens the fan in the front of the car will run at max speed "screaming". This also happens with faulty system pressure sensor.
If the evaporator temperature does not reach freezing point, it cannot be frozen evaporator issue.
Old Oct 8, 2024 | 03:37 PM
E350
Thank you all for the responses. I will see what my team at the shop can try. Besides the AC issue, I can't actually turn the AC off when I press the AC button. Someone responded that is a factory thing and is normal. But if I turn the AC completely off, I don't have fan to circulate the air. If I could do that, then maybe the unit would unfreeze and I would still have the fan to blow the air, if it it is hot and not the AC. Any fix on the AC button being able to be turned off so just the fan is running if the AC freezes up??
Thanks!
Old Oct 8, 2024 | 04:33 PM
LOOKUP AAC Module...
you can always hook up your favorite scanner to watch AAC Module datastream and DTC's
In particular see that ALL temp sensor are connected + working. Pass. footwell tends to get pulled apart during filter service
Unit keeps A/C : ON to please the windshield moisture sensor... this helps to dry the evap without foging up...
This should help restore confidence in this system.
Old Oct 8, 2024 | 11:23 PM
S-Prihadi's Avatar
The button A/C = aircond compressor only.
OFF = All off, including blower.
So you can press A/C to be off and still get blower to run
Old Oct 9, 2024 | 09:54 AM
Thanks!
It has always taken a few minutes for the A/C system to respond to being switched off in both my 212's, it's not always instantaneous. I do now turn off the A/C with the button a few minutes before I arrive at a destination. Again, I wonder if if this issue could be circumvented by setting a cabin temp or fan speed to alleviate this issue after insuring the drain line is flowing correctly and the evaporator is clean
Old Oct 9, 2024 | 10:28 AM
Jeedie's Avatar
S212 E300
Did some checks on my system, where I occasionally run into the same issue of the AC slowly blocking up after ~2 hours. I checked for the obvious water underneath the car after running the AC 100% for a few minutes. There's a nice puddle of water underneath the car, so the drains must be open. So there will be other causes for the AC to block up.
What do you mean by 'I can't actually turn the AC off when I press the AC button'. Does the red light above the A/C letters stay on?
Old Oct 9, 2024 | 03:39 PM
E350
Yes, the light stays on when I press the button for AC.
Old Oct 9, 2024 | 03:50 PM
double check AAC Module with your scanner. Circuit board features unsoldered pins that can invite grumblings come in to play.
