Sponsored by: CARiD
Mecedes w212 E350 V6 2012
Old Oct 27, 2024 | 04:42 AM
Matei2320!'s Avatar
Mercedes Eclass E350 V6 W212 2012
Hy , So i have a problem with the Water Temperature, On the road sometimes not all the time it drops to 0 and the Vans starts to cool off. I've change the Cooling Temperature and after still the same problem . Any idees ?
Old Oct 27, 2024 | 05:56 AM
S-Prihadi's Avatar
Could be the connector towards the engine coolant temperature sensor of its pin at ECM connector which has bad contact or damaged wire along the way from ECM.
Old Oct 27, 2024 | 07:19 AM
JettaRed's Avatar
Veteran: Army
Well, the faults are Stored (Historic) and not Current. Have you cleared the faults since making repairs? Is the check engine light on? Is there any Freeze Frame info available?
Old Oct 27, 2024 | 09:45 AM
Matei2320!'s Avatar
That's the funny thing it was not check engine light on.
After changing the sensor we cleared the fault stored and now is back on with additional ECU aswell
Old Oct 27, 2024 | 10:43 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
WEIRD...
says who...?
-- What module reports com issue with the ECU??
-- This looks weird because we don't yet understand.
-- What else is unstable... or is it just ECU only and chassis's working normally??
-- Bad GND and low voltage can always ready to deliver transient chaos... better take care if the basics before replacing a collection of good modules
Temp sensor is built to be reliable with sealed metal sensor.
> ​​​​​​Scanner only tells one part of the story, what's known about this vehicle ???
