Sponsored by: CARiD
Running an M273 low on oil
Old Nov 14, 2024 | 03:57 PM
mgiara's Avatar
2013 Altima, 2011 E550
I'll lose massive reputation for asking this but what's done is done at this point.
Just caught it now. Was 2-2.5qts low (9qt capacity)
Last change was 7,000 miles ago; I intended a 5,000 mile interval but budget has been tight going into the holidays.
Last change used LiquiMoly's 5W-40 kit from FCPEuro.
2qts of Castrol Edge Euro 5W-40 brought it up to the minim line, another half a quart to the middle.
My curiosity is, since the engine runs, should I stop using it until I boroscope/compression test the engine so as to prevent potential catastrophic failure and make the block non-rebuildable?
Old Nov 14, 2024 | 05:04 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
What would you do differently if a boroscope shows damage?
At this point damage has occurred, or it hasn’t.
Damage would come from a loss of oil pressure, not a loss of level. If you didn’t notice anything amiss, you’ve likely dodged a bullet.
I would consider changing the oil as soon as possible, as you may have stressed the oil while it was low (higher turnover rate, and likely higher oil temp). Changing it out will ensure that you have full protection going forward.
Old Nov 14, 2024 | 05:27 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Did you never get an add oil light? Or low oil light? Might want to check that sensor if you feel it is now proper level.
Old Nov 14, 2024 | 05:29 PM
mgiara's Avatar
You make a fantastic point; I'd not drive it and get quotes on a rebuild but wouldn't be able to fit it into the budget anytime soon.
Can't thank you enough for your reply, especially how you worded it and the insight your experience allows.
I'll not drive it until I can service it and will cut open and inspect the filter when I do. Happy to report back with photos so that those who might see this in the future see the result.
Old Nov 14, 2024 | 05:32 PM
mgiara's Avatar
Did not; was thinking after refilling it that a superhero arc to this story could be me inventing that sensor and saving a lot of people a lot of heartache 😅
So now I know the sensor exists, I will make sure I test that it's functioning correctly. Thank you so much for this!!
Old Nov 14, 2024 | 06:02 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
@mgiara You should be perfectly fine with the engine being low 2qts low. we get cars like this all the time. Your engine takes about 8.5liters so being low 2 will not hurt anything. You should have had the low oil message on at that level.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
