Sponsored by: CARiD
Fuel quality sensor
Old Nov 28, 2024 | 03:53 AM
MBMD1995's Avatar
2016 e350
Fuel quality sensor
Hey guys so Im working on my car that's been sitting for over a year & it won't start. I ran a scan using my launch scanner and received 3 codes under the control unit fuel pump. P017700, P017900 P017800 Im trying to figure out where the fuel quality sensor is located. My car is a flex gas vehicle and I’m not sure if that changes the sensor. Ive found the fuel pressure sensor online but I’m not sure if that the same as the fuel quality sensor. My vin is WDDHF8JB7GB218649 . If someone can offer any clarity, that would be great.
Old Nov 28, 2024 | 05:37 AM
S-Prihadi's Avatar
Based on MLE350 flex fuel, it is at the top of the fuel tank. Code 929
https://www.benzworld.org/threads/ml...094554&slide=0
If W212, it seems under the tank, close to it : https://mbworld.org/forums/e-class-w...ml#post8010090
If W204 C class, its close to tank,
Basically it is CLOSE to the fuel tank or at the fuel line.
https://mbworld.org/forums/c-class-w...78-solved.html
Looks like this :
Old Nov 28, 2024 | 07:13 AM
JettaRed's Avatar
Veteran: Army
I'd recognized that thumb anywhere!
On the W204 C-Class, the sensor is fairly easy to access. You just need to remove the plastic splash panels underneath the driver's side. From the diagram, it looks like the sensor may be in a similar place on the E-Class. But read the entire thread that @S-Prihadi provided because it shows the short is caused by water and how to fix the problem.
Flex Fuel Sensor on W204 C-Class
