Transmission needs to be replaced
- Both front inner C/V axle boots are torn and the joints are compromised
- both front left lower ball joints are loose
- Front right forward ball joint is loose
- front drive shaft u joint is broken and transfer case and output shaft are also broken, this is clunking you're hearing at low speeds. Unfortunately the transfer case and transmission are 1 assembly and can't be replaced separately. The transmission will have to be replaced.
What should I do? He says there is no transmission fluid leaking. It is a 2016 e400 coupe. What might be the possible causes of this issue and is it certain that I have to change my entire transmission if I want to get the car up and running.
For context: The car was running fine, but then I started hearing a knocking noise.
I looked at the video and it does look fairly clear that your forward u joint is shot. From what I remember from other posts the U-joint is part of the forward shaft and can't be replaced by itself.
I am not convinced that your transfer case has failed. There have been other cases where the forward shaft u joint has failed and I don't think that the transfer case was damaged.
My advice would be to have the forward shaft replaced and see if the clunking is still there unless they can demonstrate that the clunking is internal to the transfer case.
