Sponsored by: CARiD
How much oil is in the engine mount?
Old Dec 29, 2024 | 10:53 PM
mercerized's Avatar
2020 E450 4matic wagon
I was underneath the S212 today planning out my bearing replacement and inspecting the CV boots when I discovered tightly packed oil / dirt evenly covering the right side CV half (inner).
The oil dirt looks like it had been there for at least a couple thousand miles because last trip that I took was 12 hours thru the high desert and that was 5k miles ago.
Anyway, the engine mount is directly above the inner shaft and it was not easy to determine if it was leaking but she's at 130k miles and the original mounts which likely could be the cause.
How much oil is in one of those mounts? 100mL (4 oz.)
Thanks!
Old Dec 30, 2024 | 04:38 AM
S-Prihadi's Avatar
Its not oily oil, but it is liquid, black color, more like watery liquid when I touched it.
https://mbworld.org/forums/e-class-w...tear-down.html
100ml probable and maybe a tiny bit more.
Old Dec 30, 2024 | 10:28 AM
mercerized's Avatar
This is helpful. Probably and good idea to r/r the mounts.
