Sponsored by: CARiD
Fuse location blower motor
Old Jan 29, 2025 | 12:58 PM
zenocchio's Avatar
2011 E350 wagon, 2014 E63S Wagon
My hvac unit just stopped working. The blower motor doesn’t spin at any fan speed. It happen all the sudden. Before I order a replacement unit can you confirm which fuse is the right ione? I checked fuse 22 of the front fuse box and 75 of the rear cargo fuse box and
they are ok
Old Jan 29, 2025 | 05:01 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
https://fuse-box.info/mercedes-benz/...uses-and-relay
You can check for power and ground at the blower connector, and determine if the problem is upstream or downstream
Old Feb 6, 2025 | 04:38 PM
Ph07's Avatar
2009 initial build W212 E350 AMG PACK
For me on my RHD E350 it’s the back right fuse, possibly number 1 on the diagram, 20-25amp fuse from memory
Old Feb 7, 2025 | 11:20 AM
S-Prihadi's Avatar
they are ok
Who gave you those fuses number ?
It is so very wrong. Fuse #22 at front SAM is among the fuses for engine computer in almost all gasoline engine models of W212 and surely not HVAC blower, but is also used as radiator fan control , not main power.
Fuse #75 at rear SAM is not for HVAC blower too.
Here is the actual high power fuse location for HVAC blower. A32.
It is at F32 Front Pre-Fuse box
You are in luck, me is cleaning my F32 today...LOL.
Connector i3 is below :
The PIN 1 or the P1 is the HVAC blower fuse for USA or LHD cars
This F32 is the one on my car/ Facelift model.
MB does not sell the fuse block stand alone, but you can modify it somehow.
Here is a video of F32 tear-down, opening up the F32 is rather tricky so I heard.... the 6 clips can break
Good luck.........
Old Feb 7, 2025 | 11:24 AM
S-Prihadi's Avatar
If only AC Computer fuse, that is fuse no 12 at Front SAM
