Spark plug indexing
I've driven a couple hundred miles since I cleared the code and it hasn't returned...
genuine vs. junk
It is not about how to index plugs: (MB) PLUGS ARE AUTOMATICALLY INDEXED by design.
Genuine NGK plugs are the very best plugs there is. Internet counterfeits are defective out of the box.
GOOD PLUGS ARE SELF-INDEXED.
Personally I'd favor NGK quality but I wasn't gonna play around with swaping my MB-BOSCH for NGK at only 50k.Mi.... near 150k may be.
The tiny single iridium pin does not fire as well as more stubby dual platinums.
We don't really have a choice of what plugs the ECU ignition control is expecting.
Going back to plane things... The O-300 engine was designed with 1940s technology and I guess they hadn't figured this stuff out yet (at least economically), because they still use "massive electrodes" which are huge so that they don't wear down instantly even though they aren't made of fancy materials:
EXCEPT the cylinder gas mixture is not homogeneous. It does not apply well.
A stubby platinum has more opportunities to find a path to ionize a plasma strike than a pin head needle.
I had two Acura 3.2L V6 Type-S with high compression ratio.
A CL had platinum and TL had iridium: fish-bites champions with brang new stock iridium.... switched to platinum: all good then!
Thing is GDI needs exact spark timing so iridium single strike path is mandatory else I'd gladly switch back to dual-platinum.
It's also why I gaped down my plugs a hair at 50k.Mi to help gain reliable spark timingnoff offset aging.
reliable spark timing is from gap
I have mine 0.65 to 0.70... this way in 30kMi I will still have reliable spark gap, grown to near 0.75mm.
Each voltage spike must strikes a spark to GND. If not ECU records a penalty with CKP and Lambda feedback.
Wild Acura 3.2-TL is gapped 1.1mm on iridium non GDI. I had those at 0.8mm
Last weekend I went out to get some breakfast to heat up the engine before doing the other 4 plugs. When I was almost there, some guy cut me off and I had to do an evasive maneuver that involved full throttle acceleration. A moment later I was pulling into the parking spot at the breakfast place and felt a bit of a misfire and a flashing check engine light came on. I turned off the car, pulled out my scanner, and found a misfire on cylinder 6.
I reset the code, went to eat breakfast, and started the car back up to drive home. No more misfires and no CEL. When I got home, I plopped a new coil on cylinder 6 and replaced the other 4 plugs. Since then I have done a few full throttle pulls with no misfires or codes.
Now I need to buy another spare coil.
I've read that quality plugs are good for 100k miles? Sounds like a stretch to me. I plan to replace mine at 50k miles. Good plan?
Search using VIN-ID for most accurate match.
While you have the intake plenum removed, you'll have great access...
> Replace your Bosch spark plugs + boots (+ air filter)
> Replace the leaky Cam sensors plus disposable pigtails.
> Serpentine kit : belt + wobbly idlers + tensioner is a good peace of mind to preserve accessories.
No surprise down easy road.
Compare the threads of all replacement plugs vs. originals. How does the GND strap compare?
[nearly identical]
It's both the engine AND plug machining that's indexed to match.
There's nothing necessary do get plugs indexed within range.
