Sponsored by: CARiD
Finally M276 3.5NA engine teardown
Old Aug 4, 2025 | 09:33 AM
S-Prihadi's Avatar
Originally Posted by chassis
Excellent video, as are all of his teardown videos. It would have been nice to have this video 5 years ago!
New-to-me failure mode. Apparently from other comments, not unique to MB.
Oil leaks (front cylinder head covers, common) + oil spills (during oil change) --> oil contaminated serpentine belt --> weakened belt --> failed belt from chemical attack --> belt ingested by spinning crankshaft --> belt pushed front crankshaft oil seal into oil pump chain --> oil pump chain pushed off drive sprocket --> zero oil pressure --> seized main crankshaft bearings
Preventive action: fix oil leaks promptly, use a funnel to avoid spills, regularly replace serpentine belt, pulley and tensioners.
Seems like the block has iron liners - does anyone agree with this after watching the video?
Good to see 4-bolt cross-bolted main bearing caps.
Very probable..........
Old Aug 4, 2025 | 12:38 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
IDLERS DELIVERS RIP
Everything is as you describe besides exactly how belt became loose.
Belt did get ingested to stop oil pump at higher RPM.
Serpentine needs maintenance kit replaced on schedule, not post mortem!
> AMAZIN' IDLERS....
We know the small idlers are barely guided by a tiny plastic insert, fastened lightly into aluminum head. The idler has the ability to quickly derail the belt off track.
Once the dry bearing is compromised by heat, the amount of wobbling vibrations loosens the long center screw... the rest is history!
Old Aug 4, 2025 | 12:50 PM
Andre Cateb's Avatar
W212 (212.065/276.820)
I think a recurrent replacement of the belt might be the best prevention... such a catastrophic mode of failure is worth the extra $ in prevention.
Old Aug 4, 2025 | 01:34 PM
chassis's Avatar
2017 GLE350 4MATIC
I replaced the poly-v belt on my W166 M276 3.5NAV6 engine and it was an easy 20 minute job.
https://mbworld.org/forums/gle-class...ml#post8544125
Old Aug 4, 2025 | 03:28 PM
SERPENTIME MAINTENANCE KIT
VERY NICE maintenance thread !
The one thing I'd do differently is TENSIONER + idlers + belt kit.
A new belt on an old tensioner stays loose thus slips and gets overheated.
Conti belts are great!
Tensioners are built to carve a groove that matches old belt length.
Old Aug 4, 2025 | 09:08 PM
S-Prihadi's Avatar
I replaced complete set idler + 2 pulley + belt under 35,000KM.
Not so good the 2 pulleys due to my always high RPM.
The tensioner lost 21% of its tension, it is easy to measure .
https://mbworld.org/forums/e-class-w...ng-torque.html
Tensioner, to counterclockwise it a tiny bit to remove tight tension to belt.
OLD = 35 Nm
New = 40 Nm
Tensioner, to hit full stop ( spin counter clockwise ), spring maximum power.
OLD = 56 Nm
New = 71 Nm
Torque values using AC Delco https://www.acdelco-tools.com/index....product_id=208
