Sponsored by: CARiD
The best M276.x VVT replacement video + welding of misaligned camshaft tone wheel
Old May 15, 2025 | 01:46 PM
W205C43PFL's Avatar
Originally Posted by KristiyanPetrov
in general yes, so frustrating...
I know right
Old May 15, 2025 | 02:59 PM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
the only thing which bugs me is if you change your oil on good intervals and on top you have the solenoid plugged off - is this not something that prevents VVT from failing..? i know is subjective and the VVT already might were on his way to go bad and then maybe you plug it off but im asking in general
Old May 15, 2025 | 03:16 PM
W205C43PFL's Avatar
Actually it does help.
Old May 16, 2025 | 02:39 AM
S-Prihadi's Avatar
VVT is a high mileage wear and tear component.
It has to wear out someday and before the chain.
Like our dampers/shock absorber, it will wear out and no need for it to leak. If the nitrogen gas chamber inside the damper tube is breached, the damper will behave funny and you do not see any leak.
Old May 16, 2025 | 05:59 AM
agree but 130k km is it considered high mileage for wearing VVT if you change regularly oil
oh yes my shocks are done i ordered new but will not mount them until i fix the rattle.. i can't believe how weak are the shocks (so many ppl complain from them)
also they were not in stock for a year in MB dealer which was shock for me... (im talking specifically for the ones which have the option to make them stiff from the button console)
Old May 16, 2025 | 10:21 AM
S-Prihadi's Avatar
130,000KM is decently a lot.
My friend's M271.860 W204 C200 has super loud knock at 70,000KM.
Again it depends on how the car is driven and average speed, thus engine hours can be counted.
In Jakarta my city, my average speed is 21KM/H, thus is I do 100,000KM, that is 4,761 hours of operation.
Traffic jam, stop and go driving is really bad for everything mechanical and more so if ambient temperature is 30C and up all year round.
Variable valve timing does its variable when the RPM changes. Good open highway driving is like a nice fixed RPM and cool wind cooling everything, the engine so relaxed a such load... engine live longer.
My front SACHS damper, can't even bounce up on it own when I tested it while replacing with Bilstein B4, it was less than 25,000KM but like 5 years old back then.
Old May 16, 2025 | 10:25 AM
  #32
oookay, i have few friends with same engine and more km on dash and they haven't changed anything that's why i compare with them kind of
B4 are really difficult to find or at least last year was.. is your B4 with damping or normal b4
Old May 16, 2025 | 11:21 AM
  #33
S-Prihadi's Avatar
My B4 is regular non electric control. simple one.
Old May 17, 2025 | 05:50 AM
  #34
oh nice and cheaper ones and easy to find too...
btw related to the topic if failed VVT should we check only that camshaft for misalignment or all 4 we should check
P.S. after replacement of VVT is it needed some adaptation reset or nothing required apart of mechanically repair
Old May 19, 2025 | 02:17 AM
  #35
S-Prihadi's Avatar
Best to inspect all 4.
There is adaptation method in Xentry if I remember right. It will adapt itself overtime too I believe.
Sorry me VVT is still OK.
Old May 19, 2025 | 05:08 AM
  #36
alright we will see tomorrow i will bring her to see what's wrong
