2014 E350 Tansmission can-bus electric system failure and how much is it to replace?
SubscribeHow much is it to replace the entire Transmission can-bus system in my 2014 Mercedes E350 4MATIC? It's should be cheap right? It's just wires and cheap plastic connectors?
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,769 Times in 4,760 Posts
Why are you thinking about getting this extensive work done?Originally Posted by hat-man
How much is it to replace the entire Transmission can-bus system in my 2014 Mercedes E350 4MATIC?It's should be cheap right?
CAN-C is the (ECU - ESP - TCU - ISM - CGW/SAM - ... ) bus that's known as a "$10k" dealer charge for engine-out harness job.
Double check this is what you need.
