Sponsored by: CARiD
Illuminated star
Old Jun 25, 2025 | 10:31 AM
FLASHBACK's Avatar
2013 E250CDI BlueEfficiency 4Matic
Question Illuminated star
I have the original MB illuminated star that even was installed by the authorized Mercedes dealer according to the attached WIS document.
When this was done it was only allowed to be active when car was at a standstill with engine off but now that rules have changed i would like to be able to have it active "in motion" as well.
So i would be happy if anyone good at 12V could point me to where to modify the installation so that it starts when the DRL starts and stays active until the car gets shutoff.
A great bonus would be if i were able to turn it off whenever i wanted to with some kind of switch.
Old Jun 25, 2025 | 11:52 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CAN-BUS PROGRAMMED
MB front grill star is controlled by a CAN-Bus module.
CAN-Bus front star controller
It's not simply a cheap On/Off type of power circuit... it's likely to be also PWM modulated.
You may be better off exploring it's VARIANT CODING menu before you decide to hack into the harness.
What programming options are exposed from there ??
Use your trusted LAUNCH scanner to explore.
My star is the classic hood ornament, nothing too fancy.
Old Jun 25, 2025 | 04:17 PM
FLASHBACK's Avatar
I have access to Vediamo and Xentry but i haven't seen anything added there maybe i don¨t know what i¨m looking for.. Any pointers?
Old Jun 25, 2025 | 08:23 PM
XENTRY VARIANT CONFIG
Locate the star controller fron the list of live modules and go through it's configuration options.
See if any available setting can help you configure it as desired
Old Jun 26, 2025 | 03:23 AM
FLASHBACK's Avatar
Yeah that much is clear to me what i meant is what the module is called/named?
Old Jun 26, 2025 | 04:48 PM
FLASHBACK's Avatar
Old Jun 26, 2025 | 05:49 PM
LOOKING FOR STAR...
short list of STAR candidates
(N10-1/2 are the SAM Modules)
Unlikely ...:
A1...
N73...
One of the 9 other siblings is your Star control Module.
