Sponsored by: CARiD
Front Emblem removal with Distronic + (camera install)
Old Oct 15, 2025 | 09:06 PM
ron m.'s Avatar
1991 SC Miata, 1999 W210 Estate Wagon, 2014 W212 Sport Wagon
I searched an infinite amount on YT and here and could not find anything definitive on how to remove the front emblem (the smooth star). Most YT videos recommended that you twist the emblem counter (anti) clockwise but that didn't work (even with a commercial grade suction cup). I finally got the hint by watching sections of this video (
where the guy switched from non-Distronic to Distronic cover).
Instead of twisting, I pried three points on the emblem with a pry tool (carefully of course) to release the tabs. Again, the tabs line up with the star so just carefully insert the pry tool in that location and it will disengage with the inner tab.
The inner tabs that engage with the emblem tabs:
Also found another video (
) that explains how to remove and replace camera... mostly correct but better if the entire camera housing is removed:
That's my contribution for the day. Now if I can only solve this COMAND issue, I would get the stoke back on this car. LOL
Old Oct 16, 2025 | 02:11 AM
BenzV12's Avatar
W212 FL
Nice, besides you can consider of replacing the grill logo to a 3D one . Sorry for putting you thru some trouble but it's worth it trust me
Old Oct 16, 2025 | 11:04 AM
ron m.'s Avatar
3D logo? I'm not sure what you mean. Can you post a link? Thanks!
Old Oct 16, 2025 | 01:41 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Distronic+ Cover Lens
The stock plastic lens is transparent to the long-range radar 5GHz beam.
Non-stock cover material may require module calibration with mixed results....
As-is the radar works really well with a cover cleaned on both sides despite high-heat location.
