Sponsored by: CARiD
A Quick Fix To Keyless Go Locking Issue
Old Oct 26, 2025 | 02:46 AM
BenzV12's Avatar
W212 FL
I recently had an issue and thought I have to share it with you . It would most likely would work on other cars having keyless go as well. Well, this is what happened :
I try to lock the left rear door by pressing the rectangular button on the door handle and nothing happens . I try again, same thing . Well, I open and close the left rear door and then touch the rectangular button on the door handle , it works .
If you also encounter a similar problem as mine, open & close the door and try to lock it with the button . Hopefully, it would work on your end as well
Old Oct 26, 2025 | 01:46 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
unstable door modules
This unresponsive door modules are the tip of an iceberg. It evidence the DCU/Keyless over CAN-B are hardly stable.
This is 100% what is responsible for drained batteries while parked.
CAN-B networking is made increasingly slower.
Experiment Rebooting the chassis to temporary restore normal functionality.
Old Oct 26, 2025 | 01:47 PM
PeterUbers's Avatar
almost like open the door and triggering the door pin woke up a sleepy module and then reset the keyless touch mechanism
Old Oct 26, 2025 | 08:22 PM
Andre Cateb's Avatar
W212 (212.065/276.820)
Resoldering the keyless go module was the solution to all my keyless go issues. The FOB battery now lasts 6~8 months and all detection areas are super sensitive.
