Sponsored by: CARiD
Static LED Headlamp Cooling Fan Failure
Old Nov 6, 2025 | 11:29 PM
jpmancuso's Avatar
2014 E350 4Matic Sedan w212
My car: 2014 E350 4Matic sedan. W212 with 100k miles.
I’ve noticed an ever increasing noise from under the hood while driving and for a few minutes after shutting down. The noise has been steadily getting louder to the point that it is noticeable from inside the car while driving. It is a high pitched whine that continues for a few minutes after the car is off. I finally found the source of the noise to be a fan mounted on the back of the headlight assembly. Apparently it is a cooling fan for the static LED headlights. No alert messages but I think it’s headed for catastrophic failure. I have an appointment with the dealer to diagnose and repair the problem. My questions are:
  • Has anyone else had this problem?
  • can the fan be replaced or does the entire headlamp assembly need to be replaced?
I’ve seen the fan unit for sale at MB parts places online, but think the dealer might try to upsell me to the whole assembly. Probably a $3000+ job which would be hard to swallow on a car worth maybe $9000!
Old Nov 7, 2025 | 03:30 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Probably a $3k.Ea. which would be hard to swallow on a car worth maybe $9000!
Good job tracking down your noisy LED HL cooling Fans.
They are the okay "ball-bearing" grade but the high engine heat keeps them spinning fast with hot engine bay...
You may be able to source the $20 replacement blowers instead of whole $$$$ headlights. This is not a common repair.
Old Nov 11, 2025 | 06:04 PM
jpmancuso's Avatar
Update
I took the car to the local Mercedes dealer and was informed that the headlight assembly needed to be replaced. Total repair quote was $3,450! I also called my local non-dealer repair shop. They gave me almost the exact same quote.
Old Nov 11, 2025 | 06:11 PM
MacVidMB-V8's Avatar
W209, W124
Crazy.
Can you downgrade to Halogen?
Or look on Ebay for the LEDs.
I swapped my whole house to LEDs around 2014-16. Saved a fortune as they are all still working, crazy reliable and long life.
Might even be able to find a whole car on COPART for $3,500
Old Nov 11, 2025 | 11:17 PM
S-Prihadi's Avatar
1 headlight at this price ?
I thought that is the dynamic version price range.
Old Nov 16, 2025 | 10:26 PM
jpmancuso's Avatar
I paid the repair price of $3,400 and will be picking up tomorrow. The invoice indicates the headlight assembly is $2,600 and is the bulk of the repair cost​​​​​. I am wondering if there is any kind of appeal process with MB knowing that the LED headlight cooling fan should last the life of the vehicle and it is unheard of for this part to fail. It is obviously a manufacture defect.
