Sponsored by: CARiD
SmartKey Issues
Old Nov 30, 2025 | 01:54 PM
DBSeer's Avatar
E350 (W212)
Unhappy SmartKey Issues
Currently having a weird issue with my key/car:
No button on the keys work; the unlock, lock, trunk, or panic button, none work. Starting the car does not work. No lights on the gauge cluster at all when inserting or turning the key.
I ended up opening the car with the physical key blade and of course the alarm sounded, and I tried to start the car with the key but nothing happened, so I ended up opening the hood and disconnecting the 12V battery to stop the alarm for the time being.
The only indication of anything I saw was a small red flash when I pressed the lock button next to the panic button indicating the key battery is ok. Car battery is ok, hazards work and it's at 12.6 volts.
Do I need a new key?
Old Nov 30, 2025 | 02:14 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
A new fob battery sounds warranted. You should be able to turn the car alarm off after getting in with the metal key by starting the car with the fob- that is, pop the keyless go button out, stick in the key fob and start the car.
Old Nov 30, 2025 | 02:28 PM
DBSeer's Avatar
E350 (W212)
I have tried a new battery, doesn't change anything. Looking it up, the red flash on the key seems to indicate that it's getting power, so I think the key battery isn't an issue.
That being said, after reconnecting the battery, there is nothing at all when I insert/turn the key into the ignition switch, no indication of anything on the gauge cluster, no noise, nothing.
Old Nov 30, 2025 | 04:46 PM
DBSeer's Avatar
E350 (W212)
I think I might be needing a new key, so I called around and I'm even more disappointed:
- Dealer says $700 and the car needs to be there (so I need to get it towed 30 miles to the dealer so more like $1000)
- Almost every independent locksmith I called said their couldn't do it, one guy said he could do it for $650 but I think he might be lying
Does anyone know of any mobile service that can do key replacements? Better yet something other than the stealership?
Old Nov 30, 2025 | 05:11 PM
MacVidMB-V8's Avatar
W209, W124
Curious what “inserting or turning the key “ means. Is it actually turning?
little red light typically is a sign key is functioning at some level
can aim at phone camera and check for IR flash when button pushed
2014 and later is dealer only
Old Nov 30, 2025 | 07:13 PM
GTIBlack's Avatar
Mercedes SL R231
You haven’t told us anything about your car. Which model and year?
A locksmith might be able to code your fob if you have a 2014 or older car, and not all 2014s either. The process is somewhat involved to sync the fob with the car. Anything newer and you have to go to the dealer with proof of ownership.
Old Nov 30, 2025 | 09:33 PM
DBSeer's Avatar
E350 (W212)
Yes there is IR light upon pressing a button. It's later end 2014 E350 unfortunately. It's going in the ignition cylinder and turning just fine, normal, but with exactly no response from the car.
Old Nov 30, 2025 | 09:36 PM
DBSeer's Avatar
E350 (W212)
Sorry I forgot to mention; it is a later model 2014 E350. I suspect it cannot be done as every locksmith I've given my VIN to has said nope.
Proof of ownership shouldn't be an issue but what's really annoying is they want the car at the dealer. Towing a fully functional car feels like such a waste just to have them to plug in their xentry tool for 30 seconds or whatever.
Old Nov 30, 2025 | 09:49 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
I imagine a skilled mercedes mechanic might be able to hotwire it to get to the dealer.
Old Nov 30, 2025 | 10:33 PM
W209, W124
I don’t know about 2014 but in my 2005 the only time the EIS can turn is if key has already been accepted. So these symptoms on my car would mean bad EIS. (Or dead battery)
Do you have a key to a different car you can try? Curious if by 2014 they just let the EIS spin no matter the key.
Old Dec 1, 2025 | 12:32 AM
DBSeer's Avatar
E350 (W212)
You are correct; the EIS will not spin without the right key. I tested this by taking the PCB/motherboard out of the housing and the EIS would not spin, but it would spin when the PCB was in the housing.
I wish I had another key to troubleshoot with but I unfortunately only have one.
Old Dec 1, 2025 | 12:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
HELP GUESSING RIGHT
You are now reaching in the thousand dollar repair for your keyfob.
MB dealership network can provide timely service.
Perhaps you could use a $150 OBDII Launch scanner to research what your chassis is doing?
The solderless Electronic Ignition Slot would be a module to scrutinize for live status. At this stage we have gone passed the marginal KeylessGo trunk module.
Use a smart charger to help both your batteries not get flat.
Old Dec 1, 2025 | 01:17 PM
DBSeer's Avatar
E350 (W212)
I have a pretty nice scan tool that I will try using soon, not sure how it will work with the fully off. Sucks that the dealership is the only option, if it happened like a month after this point I'd be slightly less disappointed as at least I could get my 500k badge at the same time!
I will try one more thing though; there is a common issue with these key fobs that consists of BGA chip solder ball being loose, I am not super experienced with these tiny electronic repairs but I'll still give it a shot because worst case scenario, I go from all keys lost to all keys lost, best case, I now have another key that I might be able to do drive to the dealer with.
Old Dec 1, 2025 | 04:01 PM
DO OBVIOUS FIRST
I think you're better off troubleshooting first before you deal with reflowing a bad BGA without knowing what's wrong.
The instrument cluster does not need to be fully ON for the chassis to already be powered up.
The scanner CAN-D talks to the SAM's and CAN-B that are always powered ON anyway.
