Sponsored by: CARiD
Auxillary Battery
Old Jan 20, 2026 | 02:55 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Auxillary Battery
After 15 years, my Auxiliary Battery malfunction light came on. Called the indy who does my work and they have to see it and then order the battery and takes 1-2 days depending on when they get it. Probably from the M-B dealer in next county.
Costs either $100 or $200 depending on battery.
How long can I drive the car with the warning on?
Thanks!
Old Jan 20, 2026 | 03:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Out Of Commission
Thanks!
if you drive it long enough, R-SAM fault may go away. These batteries hardly power anything.
At 15Yrs, it's not worth splitting hair with reconditioning charge.
Its normal for AUX to loose charge when Main drains out. This may still happen with a new AUX then you can use counter measures: CTEK float charge!!
Old Jan 20, 2026 | 08:23 PM
Senecat's Avatar
1983 Nissan Shltbox
$50 for OEM battery on Amazon or ebay. Easy to replace yourself.
Old Jan 20, 2026 | 08:59 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Order from Amazon, install in a few minutes
https://a.co/d/bFj0FH2
Old Jan 21, 2026 | 02:17 AM
BenzV12's Avatar
W212 FL
Nice to see long time member
Well, I was not aware of a warning light for the Aux Battery to be honest. Different things but battery related , I could be able to drive my key fob with a warning low battery message more than 4 weeks
Old Jan 22, 2026 | 10:42 AM
El Cid's Avatar
Veteran: Army
Thanks to all!
Ironically I had not driven car in about a week when got notification. Drove it about 20 miles and notification did not come back next times started up. Replaced main battery in Nov. 2021. Will get it checked. I can get that done at Advanced or AutoZone, but they will not install a new one - company policy. Fortunately the indy can do it.
Was told years ago by M-B service manager that need to drive car 20 miles or more to charge main battery. Car has to be moving to charge battery.
Watched a video on changing Aux battery on 2010 M-B E350. Not something I want to do.
Old Jan 22, 2026 | 12:54 PM
slovcan's Avatar
2011 E350 CDI 4Matic, Rover 75, Chevy K2500, 2 motorcycles
Thanks to all!
Your auxiliary battery is failing, but not yet failed. It gave you the warning after a week of downtime, but that will gradually increase to a few days down before it loses the charge. This is completely different from the main battery. If I remember correctly, one thing I notice when the warning message was active was that the dynamic seats bolsters and massage functions didn't work. After driving a bit a replenishing the charge, it all returned to normal. In my 2011 E350 CDI it is a tiny thing that can practically fit in the palm of my hand and is mounted inside the left side of the dashboard. It is pretty easy to access through a removable panel to change. HOWEVER, some cars have it in the trunk beside the spare tire and that one is about the size of a motorcycle battery. Both are easy to change. I found one online for fire escape emergency lights. It was exactly the same in every respect, size, voltage, amperage, terminal size, type and orientation. It cost 13 Euros.
