Sponsored by: CARiD
ball joint and front hub bearings replacement
Old Mar 6, 2026 | 04:44 PM
adisco93's Avatar
2007 E350 4matic- winter edition
I need to have the ball joint and front hub bearings on my 2014 replaced. How much shall i budget for such a job and can any independent mechanic shop do this for me or should i head to the dealership for this work?
Old Mar 6, 2026 | 05:11 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Yes, go to your Mercedes Indy. Save the dealer for advanced repairs.
Replace control arms also and stabilizer links.
Note there are two front ball-joints per side.
Why are you replacing the front bearings, why not take 10mn to adjust the freeplay ?
Budget from $500 to $1500 or less than $2k according to the extent of repairs.
Old Mar 6, 2026 | 08:43 PM
adisco93's Avatar
Thanks for the response. Replacing because there is a very loud rubbing noise coming from the front wheels. A MB technician drove it and indicated that the ball joints and hub bearings was the issue and needed to be replaced.
Old Mar 6, 2026 | 08:51 PM
AlexMonroe75's Avatar
I've done this mod on my '22 GLB, it's a pretty straightforward process, just make sure to grab the right tools and a bearing separator will save you a headache with the front hub bearings.
Old Mar 6, 2026 | 09:26 PM
Yes, that makes sense for a bad wheel bearing + BJ for deep pothole or curb contact.
Check the strut itself is not bent by weighing down on the suspension.
Old Mar 8, 2026 | 10:32 PM
adisco93's Avatar
Thanks all.
