E-Class (W213) 2016 - 2023
Hardwiring Radar Detector
Old Aug 22, 2016 | 07:09 PM
userix's Avatar
E300 2017
Does anyone know where to tap into the mirror/sunroof control console area for a switched power source to hardwire a radar detector in the new 2017 E300s?
Old Jul 23, 2017 | 05:33 PM
schtuggie's Avatar
2017 MB E350 4Matic
Did you ever get an answer to this? I just took delivery of my 2017 and wanted to install as well since there is no other power source for my Escort. What did you use as a mount? Thanks
Old Jul 23, 2017 | 05:40 PM
ua549's Avatar
Though I no longer use a radar detector because radar has been replaced by LIDAR, I used to connect to the power in the sun visor.
Old Jul 23, 2017 | 10:39 PM
gorillamunch's Avatar
GL
Where I'm at....
I am a bit fearful of taking the mirror housing apart ... but was able quite easily to run the Valentine 1 RJ-11 cable in the headliner, tucked in down the right of the windscreen & from there down to the passenger foolwell fuse box.
FYI I used a tap to run power off of a 5amp mini fuse & grounded to a threaded nut that's in the fuse box. However none of the mini fuses seem to be switched so i'm waiting for a ATO size tap I ordered to arrive - hopefully one of this is switched power. Will keep you posted.
Old Jul 24, 2017 | 07:45 AM
ua549's Avatar
I connected to the sun visor wire above the headliner near the hinge.
That may not be switched in the W213.
Old Jul 25, 2017 | 02:05 PM
greasykid's Avatar
2015, ML250 BlueTEC
Have mounted Valentine V1 on sun visor of many MB's. Run power cord down the A pillar to either the fuse box or center console. My local shop does this in less than an hour. Not a big job.
Old Jul 25, 2017 | 06:06 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Anyone know where to find the fuse box(es) schematics?
In particular the one in the boot/trunk.
I need to install 2x 20 fuses that switch off when car's off.
