Gasoline E class - Direct Injection problems - resolved?
Another crucial thing is decent fuel, never use less than 91RON. In addition top tier gas contains additional additives to ensure clean combustion. Paradoxically, ethanol which is otherwise detestable because it's hygroscopic has a very high octane rating which leads to very predictable detonation (no more than 10%). As is recommended in the manual, if you ever run fuel of less than 91 octane, make sure you fill your tank with premium at the earliest possible opportunity.
http://consumerreports.org/car-maint...h-extra-price/
Octane rating and whether or not a gasoline is top tier are unrelated.
I am not saying that MB has a DI problem, or that any particular new car will. But I do understand the concern based off of past experiences for people across several makes.
It doesn't explain why there wasn't a CEL but they were tearing down the engine for another issue. Wish I had my phone on me for a pic!
The main thing that saves the MB engines is good PCV control. The engines pull down a ton of vacuum and have good built-in oil separators, so you don't have lots of oil hitting the valves to cause buildup. The higher mileage 276s we see aren't having any significant buildup, but they are all N/A, turbo cars suffer worse normally due to more oil in the system from the charge air system. Even though we don't tear down many 271s, they don't seem affected yet, certainly not like the BMW systems, or the early Chevy Ecotec 4 cyl engines that caked up valves very badly. Both of those were due to poor PCV systems that don't pull the oil out of the charge air.
We do see way more injector failures on the DI cars than you will ever see on a port fueled car, and the injectors are much more expensive. Will be an issue for people out of warranty coverage, as one injector will be in excess of $1000 to replace.
Still though I don't see any systemic issue of carbon buildup on MB DI engines which surprises me. That said, I also don't see any systemic issues on the 3.0TFSI engine from Audi, and I have received confirmation that no, we here in N. America do not utilize dual injection as per several Audi World forum sources. DI engines are Audi are just that - DI only, unlike say the Lexus dual injection system.
That said, it seems MB and Audi have fixed their issues.
Pls please please leave the talk about fuel additives from here. It'll make me have even more grey hair. It does not matter that you guys are doing that. Most fuel additives do not even survive combustion, except those with a high amount of PEA, such as Redline SI1 cleaner, but that also causes pretty accelerated breakdown of your engine oil, so best to do an oil change after running that (e.g. it is not something you want to be doing every so often).
Moderation is key, but please, let's leave fuel additives from here...
That said even I have given up and my next car will have DI.
While the use of a high-quality fuel will not reduce these deposits on the valves since the fuel is really not injected onto the valves but in the combustion chamber next to the spark plug, our MB engines usually have high compression (the M276 has a 12.5:1 compression) which require higher octane fuels, and the expensive DI injectors need to be kept clean as one can never tell when the fuel, even from a reputable supplier, can be tainted which could begin to clog the injectors. That is why I use an additive, as well as it keeps the fuel lines, fuel pumps and EFI systems cleaner than not using any additive (I use Liqui Moly stuff).
I use the Liqui Moly oil is in the M276, which appears to be an oil which is of a higher quality than Mobil 1, but it's arguable as I've not used it for very long now in both of our cars (1998 SLK 230 Kompressor and the 2013 C300 4Matic sport). I once used Amsoil for a couple of oil changes in our first Benz, a 1986 300SDL, without problems but it was more expensive and harder to find locally, so I went back to Mobil 1 until the first oil change earlier this year on the C300.
At 66k miles, the M276 engine still has strong performance and gets good mileage, especially on the highways.
I will be changing out the spark plugs today and changing the oil tomorrow in the C300 so I will at least be able to see how well the fuel burns and how the oil appears. I may send a sample of oil off to George Murphy or someone who can analyze it. If I do, I'll report the findings.
Also, my 2013 C300 was originally a NY state car, so it has the charcoal filter on the engine side of the intake air filter assembly. I've been contemplating removing it to have freer flowing air at the intake since it seems to restrict a considerable amount of air (guessing about 25% since about that much of the surface area of that filter is solid plastic). Only problem is: to remove it you have to destroy the plastic tabs, negating any replacement of that filter if needed. It is allegedly there for a few states to reduce the amount of gas fumes escaping the engine upon shutdown of the engine. This could also affect the valves since the air is directly being fed to the valves before the injectors in the combustion chamber inject the fuel. So, the air is mixed in the combustion chamber with the fuel and not above the valves before the valves are opened for ignition in the combustion chamber. More air could lead to leaner mixtures, but the ECU will control the flow (at the throttle body) and mixture in the combustion chamber as a direct result of the MAF sensor readings. A freer flowing engine seems to be better than one which restricted, but I am not sure about how this might affect the deposits on the valves and in the intake passages.
I don't have experience with Liquimoly myself, and the only oil I swear by on my PFI engine is the Mobil 1 0W40 product. Would I use it on the M276 once I get it? I'm not so sure as that oil does shear relatively quickly to a low-mid thirties. I used to run German Castrol (0w30 made in Germany) on my 2.0 FSI engine and that actually performed surprisingly well. These low SAP oils though, ugh, they bother me (much for the same reason as 229.6 oils). We're trading fuel economy at the expense of engine longevity, and as someone who loves keeping their cars a while, this pains me.
That said, I have no choice but to jump onto the DI bandwagon now, much to my dismay. MB does seem to be doing a good job though. On my B7A4 with the first DI mass produced engines from Audi, I went through a new PCV valve every oil change (no joke). Even when I sold it back in 2012, I was on the 6th revision that Audi had out, and it still was wrecked every 7500km. If there's one thing I don't see on the MB side of things which has me smiling, is there doesn't seem to be a mass PCV issue, nor does there seem to be rough idle concerns/CELs and the lot which is associated with DI engines.
In any case, back to the DI subject...the PCV system on this DI engine seems to be working quite well and I look forward to many miles of incident free driving.
It's been a great workhorse and good to hear about the 276. Done deal, S450 here I come (once they release the vehicle in September!)
Thanks to people like you for your support in helping me navigate the labyrinth. The other thread involved Audis and after thinking it through, reliability is more important to me than anything. The M276 engine in the S class, being that it's been around a while and the fact that this may be one of the last years of being able to buy a S without the mild hybrid drive system sealed the deal. I love new technology (it pays my bills), but not in cars. Until the order is placed, I will still peruse the E class forums, but now it's a matter of hurrying up and waiting. September can't come soon enough
Oh, I tried changing plugs today... couldn't get the #6 coil out so I buttoned it back up and will take it into a buddy's shop (whom I have used for years) to put the dang things in. Ugh.
Good luck with the S450... I like the S-class but we no longer need a large car. If I had to buy another Benz at this time, I'd either go back to a W210 E55 or E300TD or maybe an older W126 300SE. Owned both a W126 300SDL and a W210 E300TD at different times, but, alas, both were totaled (no one injured and both were in the city at lower speeds). Loved the W210. It had 180k miles and still had exceptional power and turned over 32mpg on the road. Great car and it was in top condition, which helped with what insurance paid me for it. Loved our 1993 W124 300E 2.8 as well. Great car which is still being driven by a friend's daughter and it now has well over 200k. If I would buy a new Benz, it would be an E-class or maybe a C... not sure. It would have 4Matic, as that is great here in the snow belt (Ohio).
