9G Transmission
To be honest, the 9G + miserable engine makes for an enjoyable drive compared to my W212's 7G cludgebox + V6. Engine noise is minimal at highway speeds, usually overcome by wind & road noise, which is also quite minimal. It also has a healthy / enjoyable amount of torque with minimal delay in spooling up.
The only time I dislike the new engine is at idle, where you can feel its roughness compared to the smoothness of the outgoing E350 normally-aspirated V6. I do wish Merc would have made this a hybrid or at least given us a bigger battery + electric aircon compressor. Then the engine could stay off at red lights every time, providing tranquil smoothness at idle. Of course, if it did that, some would argue that they couldn't justify buying an S-Class, so perhaps this was intentional.
I have driven my GLC300 4matic only 1100 miles and cannot feel any transmission shifting (I do hear some) so I{m happy driving but can't find any info on when to have it serviced.
Is that when you are getting your 725.x transmission serviced?
Brochure title:
Global Training – The finest automotive learning
Cars · Drivetrain
9-Speed Automatic Transmission (725.0) · AKUBIS®
direct special • Final Test · Go
Hand-outs for participants
from section 2.3
Maintenance information
Maintenance
• Oil change interval as per NAT2FE+ every 125,000 km/5 years
• Exchange of both oil filters in the oil pan, the oil pan must be replaced for this as the
filters are permanently integrated into the oil pan every 125,000 km/5 years
• Exchange of the pressure oil filter on the front integral carrier based on service
sheet specification
• Use of the new automatic transmission fluid Shell ATF D97 (Mercedes-Benz Specifications
for Operating Fluids 236.16)
The new automatic transmission fluid has the following part number:
A001 989 92 03
General information on transmission 725.011 2
Maintenance information 2.3
T0831E
I had wondered if I we need to clear the "driving data" that the car saves about our driving styles. In my wife's VW , clearing the data ( pressing brake pedal for 10 secs with ignition key in before starting ) would make the DSG transmission run like new again. I read MB's have a similar way to clear the data but not sure if that's what its required
I don't know the ins and outs of the W213 drive train but I would not be surprised if MB's intelligent software / shift point adjustments also suffer similar limitations making a periodic reset a good thing. Below is a site i came across which explains how to do a reset on pre 2017 MB cars. Judging by the article and the comments, I am convinced this issue is also am MB problem and the reset does work.
http://www.mercedesmedic.com/reset-m...-instructions/
If I can find info on how to reset a W213, will try it myself.
What about service/maintenance? I have a Service Sheet for my model 253 that says "replace automatic oil and filter at 60,000 (and 120,000) miles for Transmission 725". Do you agree?
Anyone have the service yet?
If so, what was cost?
Not something I would care to tackle, they drained the torque converter as well as replaced the pan. I wouldn't want to get the level incorrect.
"I think you will find the 9 speed transmission to be a Godsend. That is precisely the tranny MB has been looking for to put in these kinds of cars, especially in terms of driveability. This is what sets MB apart.
I say this not because I own or have even driven the e45, rather from my experience with the 2017 CLS550. Although not AMG, the ride is super exhilarating nonetheless. The 278 motor is a bi-turbo V8 producing 402 hp/443 lb-ft torque which exceeds the ratings of the 6 cyl. e45 but as I said, it is not AMG and should not be compared in those terms. If the e45 has the same tranny as my CLS (I think it does) it will be more than capable of producing smooth, seamless shifts throughout the range of the most powerful MB motors (the 63 S is another animal entirely!).
You will have the added bonus of very good efficiency as well. My car has not yet been broken in as I have 3000 miles on it but I have driven the heck out of it (often in sports mode) and have averaged nearly 23 mpg. The transmission will be in 9th gear riding along at 70 mph at only 1400 rpms - that is almost diesel-like. Of course sports mode jacks that up two fold but the efficiency is not compromised that much.
The driveability factor of this transmission is the last thing to worry about even in higher performance Mercedes cars. I think this is due to the wide space between gears and its ability to even skip gears (in downshifts) which maximizes the smoothness and quickness of the car overall, making it ideal for the performance segment. Previously, I owned a Mercedes with the seven speed and there is no comparison whatsoever - the 9G-Tronic is as good a tranny as you will find".
In my experience, MB has never really been good at making transmissions, but this one is leaps and bounds over the old 7G.
Today, for the first time, something weird happened at a stoplight.
The car's auto stop kicked in, and when I released the brake to go, the engine fired right up, but I was trying to accelerate and it wasn't in gear. It just revved up a bit and then caught on after a second or two.
Very weird.
One of the peripheral module gone lazy is causing the extreme delay you experienced during an ECO restart.
Nothing is supposed to affect the TCU-ECU timings.... but in reality things are a bit different!
TCU is affected by ECUECU is affected by F-SAMF-SAM is affected by everything.
> When TCU is in shape it shifts gears up and down seamlessly as fast as a machine gun. Always in perfect synch with what the gas pedal is asking.
> When bogus delays are introduced TCU lags a bit behind what the engine is doing. Shifting decisions act confused and react slowly. Downshifts can be harsh. Upshifts hang on rpm for no reason... No errors are directly logged by TCU, codes are in remote modules
While your tranny is moody, take it easy to prevent building clutch sludge over the valve screens.
Monthly reset of adaptations or ATF Sce do nothing to help this issue.
If you have DistronicPlus: you'll also notice delayed reactions followed by heavy braking. No faults!
While driveable, impacted vehicles are operating in a degraded mode. This is like a super nimble limp-mode that almost feels normal to drive... I dont know of any MBenz TSB published to fix that broad issue. Adaptations only deal with poor tranny shifts - Tranny is not the cause of the issue here. Clutch shifts are perfectly well executed, only out of band at the wrong unexact delayed time.
This Benz favorite decade old CAN issue should earn many fault codes, much like cam-crank correlation faults. It is sad to see how couple details are causing these great tech-stacks to underperform straight from factory.
