Few Issues....
Brought my car in for the 2nd time for same issues.
The seat is making weird noises (the upper part)will squeek when pressed against it,the lower part will move about half a cm forward when taking off and again when coming to hard stop.
The Internet in the car feature works when it will,it give me a lot of error messages.
The Service provider Vodafone and Swisscom say its an issue with the car,and Mercedes says the opposite.
Sometimes it works and mostly it does not.Vodafone says my car keeps deleting the sessions...?
The Nav System will tell me to turn left in a Tunnel
When the Pilot is switched on,and you drive on the freeway the system reads the Speed limits and will adjust speed accordingly.Except sometimes it feels like it need to drive 60 kmh per hour and of course there is no 60 kmh speed limit anywhere...Kinda dangerous.
Whats funny is that the Dealer will of course say that they can not find any flaws with it...Typical.
Has anyone experienced similar issues and what has been done about it.
Thank You
My heater/boiler at home had the same problem. When the utility service tech came out it started perfectly. He replaced a pressure switch a week later and it works perfectly every start up?
I've switched the features off that reads speeds signs and adjusts adaptive cruise settings. It was reading the "limited to xx kph/mph" signs on backs of trucks. A lot have 50mph round speed stickers on their back end and I'd frequently get braked from 85 down to 50 when passing lorries that have them. Very annoying.
So now it does not read the signs at all,correct?
i kind of need that here in Switzerland where the speed limits change so often it gets confusing....
. Same menu let's you have speed displayed in driver and COMAND displays and let's got set visual and audible alerts if you exceed limit by whatever amount you choose
Is it possible to adjust the speed limit pilot too to make the car drive e.g. "at speed limit + x miles per hour"?
That limit doesn't change speed pilot, that just sticks to legal limit and changes according to whatever speed sign it has read.
If/since the adjustable alert only comes with speed pilot, it could make the speed pilot useful even if not used as active CC.
